Virtual HVAC selector without "temperature" (Fil Pilote)
Hello there,
I am pretty new to Home Assistant, comming from the Domoticz world, and I have an device that have 4 states presented by MQTT.
This device is controling using french “fil pilote” the heather that have it’s own thermostat.
I would like to have the following “buttons”:
  • Confort
  • Eco
  • Hors-Gel
  • Off
    (and maybe later:
  • Confort -1°C
  • Confort -2°C)
I figure to get this using MQTT with the following template, but I would remove the “temperature” thing which is not interesting for my usage (in my configuration.yaml)
mqtt:
 climate:
   - name: "Fil pilote"
     unique_id: chalet_fil_pilot
     payload_on: 1
     payload_off: 0
     modes:
      - heat
      - heat_cool
      - cool
      - 'off'
    mode_state_topic: "filpilot/Status"
    mode_state_template: >-
      {% set values = { 'Off':'off', 'Hors-Gel':'cool', 'Eco':'heat_cool', 'Confort':'heat'} %}
      {{ values[value] if value in values.keys() else 'off' }}
    mode_command_topic: "filpilot/set"
    mode_command_template: >-
      {% set values = { 'off':'Off', 'cool':'Hors-Gel', 'heat_cool':'Eco', 'heat':'Confort'} %}
      {{ values[value] if value in values.keys() else 'Off' }}
    availability_topic: "filpilot/availability"
Any good hint I can use for make this better?
