So I’ve been following numerous posts about setting up Alexa to respond based on the brightness of a virtual light. Unfortunately I can’t seem to get my setup to recognize that the light has a brightness attribute. Here is my code for setting up the light which is in my configuration.yaml. When I go to the Dev Tools Templating, I get “None” when I try to return brightness.
Now I can retrieve the brightness. If I go to Dev Tools and set the brightness, it returns as expected. Now the next issue. When I have Alexa set the brightness, I get 0. Doesn’t matter what I put in. Do I need to use Emulated Hue in this case?
I was able to get it working. I decided to go the route of hass-virtual by twrecked.
Installed that using HACS and put it in the configuration.yaml. Once that was done I just had to update my entity ids appropriately and it was off and running.
Okay so I’m pretty new to the whole Homeassistant thing and I just can’t figure out how to get the Hcas integration to work. Don’t know where to write the various things inside yaml. can you help haha?
