Here’s a Virtual Nuki Bridge addon.
Use it instead of the physical Nuki Bridge.
Still might have some glitches but have been working for me smoothly for a few days now.
If you have Home Assistant OS installed on RPi 4 not too far from your Nuki lock, it should work fine. Other setups not tested yet.
Everything’s with the addon works fine….Nuki is paired…. But got no connection with the.
Official Home Assistant Nuki integration or
hass_nuki_ng.
Useing 127.0.01 with the paired token from log….
Connection Issue ?any idea….
Does it works with esp bluetooth proxy? Im having issues trying to configure it that way.
