I want to integrate my PEHA PHC 942 STM domotica-system in HA. This because PEHA only support his own brand devices and Enocean wireless devices but no audio-systems, webcams etc.
I can control the 942 STM (also) via URL-action codes. It works already via IFTTT on my Google home(s) and Alexa dot (outside HA) but i don’t have a clue how to make a (virtual) switch within HA that can execute a URL Action code. So for example something like beneath:
Further i already integrated Alexa and Google home in HA, so when i could find how to execute URL Action codes it would work voice controlled without the use of IFTTT.
according to the documentation the part above for the switch should work as long as it is formatted correctly.
if you select your code snippet above and click the </> button in the editor window it will display the way you have it formatted in your config. if it is incorrect then we can see it.
Thanks for your reply, what do yoy mean with “</> button in the editor window”?
E.g. where is the </> button and where is the editor window? (I’m new with HASS)
I now use a samba-share (mounted to /config) with notepad to set things in the configuration.yaml.
Should i do otherwise?
Best regards,
Léon
PS. Is there a (downloadable) manual for HASS so i don’t have to sit hours behind a computer? (i have a hernia at the moment)
when you are typing to add (or edit) a post, where you are typing is what I call the editor window. at the top of that window is where you will find the symbol to click to properly format the code.
It’s best to do that any time you post any code because yaml is very spacing critical. that way people can see exactly how you have it entered into your config and can spot potential issues.
how you edit your code isn’t as big of a concern as long as the editor you use doesn’t do any funky hidden formatting to it. I use WinSCP and Notepad++. Others use different editors. As far as I know Notepad should be OK but I’ve not used it for code editing so take that for what it’s worth.
And unfortunately, no there isn’t any “manual” per se. Just the online documentation. It is easier to maintain for the developers I guess. However my biggest complaint has always been the vague/scant/incomplete documentation for home assistant.
The good news is that the forum here is usually very helpful with lots of very knowledgeable people. If it hasn’t already been answered and found in a forum search, most times (most…) someone should eventually be around to help you out.
Like i said, when i put the url in a browser the bulb is switched, so the action code is 100% correct. The button it self reacts in HA but nothing happens with the light bulb
if you type the complete command directly into a linux shell terminal from where you have Home Assistant installed exactly as you have it in your configuration does the light switch on/off?
Dan kunnen we ook gewoon in het “Belgisch” verder communiceren wat jij?..hahaha
Nee, eerlijk gezegd heb ik dat een jaar of wat geleden uitgezocht maar verder weinig tijd meer gehad voor HA, druk druk druk. Misschien dat ik tijdens de Kerst er weer eens verder naar kijk want een terugmelding was ik toen ook naar aan het zoeken maar gestopt omdat het slechts hobby is en ik verder (te) druk ben met mijn werk.
Wellicht dat het ergens in de PHC-software te vinden is binnen LED-terugmeldingen ergens in de vorm van een event?
Je zou ook PEHA kunnen benaderen waar de URL’s te vinden zijn van de terugkoppelingen zonder iets over HA te noemen. Als je het eerder vind qua tijd mag je het mij vertellen…hahahaha, ga daar voorlopig niet veel tijd meer insteken. Heb er mijn airo’s en muziek (o.a. ROON) inzetten, twee camera’s, Tuya spul en wat Geo.
Veel plezier met het onderzoeken van alle mogelijkheden en alvast fijne feestdagen,
