Hello !
Is it possible to realize a virtualpowermeter?
So I assign a value to a lamp z.b 8 watt and a counter on the basis of the states on / off the consumption calculated.
Would like to know this also!
Iām doing something like this for my lights with template sensors
Assuming a lamp consumes an average of 9.5 watts, the current power consumption in watts (āWā) can be calculated with a template sensor in the sensors.yaml
as follows:
sensors:
stromverbrauch_light_deckenlampe_bad:
unit_of_measurement: "W"
entity_id: light.deckenlampe_bad
value_template: >-
{% if is_state('light.deckenlampe_bad', 'on') %}
9.5
{% else %}
0
{% endif %}
And for the power consumption over time in kWh you can combine a template sensor it with an history sensor an calculate it as follows:
- platform: history_stats
name: Deckenlampe Bad AN Jahr
state: 'on'
type: time
start: '{{ now().replace(month=1).replace(day=1).replace(hour=0).replace(minute=0).replace(second=0) }}'
end: '{{ now() }}'
sensors:
gesamtverbrauch_light_deckenlampe_bad:
value_template: '{{ states.sensor.deckenlampe_bad_an_jahr.state | multiply(0.0095) | round(2)}}'
unit_of_measurement: 'kWh'
friendly_name: 'Gesamtverbrauch Deckenlampe Bad'
A quick hint. My history sensor (history_stats) used here, which measures how long a certain light was on during this year, automatically resets at a new beginning of the year.
So I only measure the annual consumption for the current year in Homeassistant. If you want this to be different, you have to adjust the history_stats sensor accordingly.
Hope that helps you a little?
yes fine, next step calculate price day, month
I think you can accomplish this already by using a switch or light entity, a template sensor and a utility meter?
Untested:
platform: template
sensors:
mylight_power:
value: >-
{% if is_state('light.mylight', 'on') %}
8
{% else %}
0
{% endif %}
unit_of_measurement: W
utility_meter:
etc.
