Trying to get a Vision Z-Wave Gen.5 (has OZW support) going it’s not integrated on the fly, but somewhat says ‘Hello’ in dmesg:
[ 3668.591394] usb 1-1.3.4: new full-speed USB device number 15 using dwc_otg
[ 3668.694216] cdc_acm 1-1.3.4:1.0: This device cannot do calls on its own. It is not a modem.
[ 3668.697285] cdc_acm 1-1.3.4:1.0: ttyACM1: USB ACM device
[ 6233.309583] usb 1-1.3.4: USB disconnect, device number 15
[ 6256.604908] usb 1-1.3.4: new full-speed USB device number 16 using dwc_otg
[ 6256.704909] usb 1-1.3.4: device descriptor read/64, error -32
[ 6256.895114] usb 1-1.3.4: device descriptor read/64, error -32
[ 6257.084979] usb 1-1.3.4: new full-speed USB device number 17 using dwc_otg
[ 6257.184861] usb 1-1.3.4: device descriptor read/64, error -32
[ 6257.374865] usb 1-1.3.4: device descriptor read/64, error -32
[ 6257.484977] usb 1-1.3-port4: attempt power cycle
[ 6258.304853] usb 1-1.3.4: new full-speed USB device number 18 using dwc_otg
[ 6258.327455] cdc_acm 1-1.3.4:1.0: This device cannot do calls on its own. It is not a modem.
[ 6258.331790] cdc_acm 1-1.3.4:1.0: ttyACM1: USB ACM device
I added it manually and stuff was compiled, but then it said: “not configured properly” or the like:
The options.xml is in that dir.
If I put either of the incoherent usb_path or device, it’s something else. What is the question.
My lsusb ouput:
Bus 001 Device 024: ID 1cf1:0030 Dresden Elektronik
Bus 001 Device 012: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 004: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 003: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
To: /mnt/dietpi_userdata/homeassistant/deps/lib/python3.8/site-packages/python_openzwave/ozw_config/vision/zu1401jp.xml
I’m sure it’s not just a matter of creating a file and chmod homeassistant.
And then it’s the thing with that it identifies it self as a: Bus 001 Device 054: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
