Visonic MCT-320 trouble setting up
I have a bunch of these Visonic MCT-320’s from my Xfinity home security install. Now slowly making the switch to home assistant, trying to move these over. I was able to reset them, and pair them with my HUSBZB0-1, but they show up as unknown.
Any suggestions are very welcome, maybe also suggestions for some sensors to replace these…
ZigBee Signature
  "node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4256, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=0, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0xffff",
      "in_clusters": [
        "0x0000"
      "out_clusters": []
  "manufacturer": "unk_manufacturer",
  "model": "unk_model",
  "class": "zigpy.device.Device"
Pairing log part 1 of 2
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
[0x5457:1:0x0019] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=240 command_id=1>
[0x5457:1:0x0019] ZCL request 0x0001: [0, 49887, 3, 337135244, None]
[0x5457:1:0x0019] OTA query_next_image handler for 'CentraLite Systems 3156105': field_control=0, manufacture_id=49887, image_type=3, current_file_version=337135244, hardware_version=None
[0x5457:1:0x0019] No OTA image is available
Device 0x6f8e (00:0d:6f:00:02:5d:75:49) joined the network
[0x6f8e] Requesting 'Node Descriptor'
Tries remaining: 2
[0x6f8e] Extending timeout for 0x51 request
Skip initialization for existing device 00:0d:6f:00:02:5d:75:49
[0x6f8e:zdo] ZDO request ZDOCmd.Device_annce: [0x6F8E, 00:0d:6f:00:02:5d:75:49, 128]
Ignoring message (b'14a0100001') on cluster 1280: unknown endpoint or cluster id: 1
[0x6f8e] Node Descriptor: NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4256, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=0, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)
[0x6f8e] Discovering endpoints
Tries remaining: 3
[0x6f8e] Extending timeout for 0x53 request
[0x6f8e] Discovered endpoints: [1]
[0x6f8e:1] Discovering endpoint information
Tries remaining: 3
[0x6f8e] Extending timeout for 0x55 request
[0x6f8e:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=65535, device_version=0, input_clusters=[0], output_clusters=[])
[0x6f8e] Extending timeout for 0x57 request
[0x6f8e:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=87 command_id=Command.Read_Attributes_rsp>
[0x6f8e] Extending timeout for 0x59 request
[0x6f8e:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=89 command_id=Command.Read_Attributes_rsp>
[0x6f8e] Extending timeout for 0x5b request
[0x6f8e:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=91 command_id=Command.Read_Attributes_rsp>
[0x6f8e:1] Manufacturer: None
[0x6f8e:1] Model: None
Checking quirks for None None (00:0d:6f:00:02:5d:75:49)
Considering <class 'bellows.zigbee.application.EZSPCoordinator'>
Fail because device_type mismatch on at least one endpoint
Considering <class 'zhaquirks.gledopto.soposhgu10.SoposhGU10'>
Fail because endpoint list mismatch: {11, 13} {1}
Considering <class 'zhaquirks.lutron.lzl4bwhl01remote.LutronLZL4BWHL01Remote2'>
Fail because profile_id mismatch on at least one endpoint
Considering <class 'zhaquirks.netvox.z308e3ed.Z308E3ED'>
Considering <class 'zhaquirks.osram.a19twhite.A19TunableWhite'>
Fail because endpoint list mismatch: {3} {1}
Considering <class 'zhaquirks.philips.rom001.PhilipsROM001'>
Considering <class 'zhaquirks.philips.rwl020.PhilipsRWL020'>
Fail because endpoint list mismatch: {1, 2} {1}
Considering <class 'zhaquirks.philips.rwl021.PhilipsRWL021'>
Considering <class 'zhaquirks.smartthings.multi.SmartthingsMultiPurposeSensor'>
Considering <class 'zhaquirks.smartthings.tag_v4.SmartThingsTagV4'>
Considering <class 'zhaquirks.xbee.xbee3_io.XBee3Sensor'>
Fail because endpoint list mismatch: {232, 230} {1}
Considering <class 'zhaquirks.xbee.xbee_io.XBeeSensor'>
Considering <class 'zhaquirks.xiaomi.mija.smoke.MijiaHoneywellSmokeDetectorSensor'>
device - 0x6F8E:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: True
device - 0x6F8E:00:0d:6f:00:02:5d:75:49 has joined the ZHA zigbee network
[0x6F8E](unk_model): started configuration
[0x6F8E:ZDO](unk_model): 'async_configure' stage succeeded
[0x6f8e] Extending timeout for 0x5d request
[0x6F8E:1:0x0000]: bound 'basic' cluster: Status.TABLE_FULL
[0x6F8E:1:0x0000]: finished channel configuration
[0x6f8e] Extending timeout for 0x5f request
[0x6f8e:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=95 command_id=Command.Read_Attributes_rsp>
[0x6F8E:1:0x0000]: initializing channel: from_cache: False
[0x6F8E:1:0x0000]: 'async_configure' stage succeeded
[0x6F8E](unk_model): completed configuration
[0x6F8E](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790795.6558754)
[0x6F8E](unk_model): started initialization
[0x6F8E:ZDO](unk_model): 'async_initialize' stage succeeded
[0x6f8e] Extending timeout for 0x61 request
[0x6f8e:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=97 command_id=Command.Read_Attributes_rsp>
[0x6F8E:1:0x0000]: 'async_initialize' stage succeeded
[0x6F8E](unk_model): power source: Battery or Unknown
[0x6F8E](unk_model): completed initialization
Device 0x6f8e (00:0d:6f:00:02:5d:75:49) left the network
[0xD9B9:1:0x0b04]: async_update
[0x3CDC:1:0x0b04]: async_update
[0xC36D:1:0x0b04]: async_update
[0xd9b9:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=99 command_id=Command.Read_Attributes_rsp>
[0x3cdc:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=101 command_id=Command.Read_Attributes_rsp>
[0xc36d:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=103 command_id=Command.Read_Attributes_rsp>
Device 0x6a83 (00:0d:6f:00:02:5d:75:49) joined the network
Device 00:0d:6f:00:02:5d:75:49 changed id (0x6f8e => 0x6a83)
[0x6a83] Extending timeout for 0x69 request
[0x6a83:zdo] ZDO request ZDOCmd.Device_annce: [0x6A83, 00:0d:6f:00:02:5d:75:49, 128]
Ignoring message (b'14a0100101') on cluster 1280: unknown endpoint or cluster id: 'No cluster ID 0x0500 on (00:0d:6f:00:02:5d:75:49, 1)'
[0x6a83](unk_model): started initialization
[0x6a83:ZDO](unk_model): 'async_initialize' stage succeeded
[0x6a83] Extending timeout for 0x6b request
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=105 command_id=Command.Read_Attributes_rsp>
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=107 command_id=Command.Read_Attributes_rsp>
[0x6a83] Extending timeout for 0x6d request
[0x6a83:1:0x0000]: initializing channel: from_cache: False
[0x6a83:1:0x0000]: 'async_initialize' stage succeeded
[0x6a83](unk_model): power source: Battery or Unknown
[0x6a83](unk_model): completed initialization
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=109 command_id=Command.Read_Attributes_rsp>
[0x6a83] Extending timeout for 0x6f request
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=111 command_id=Command.Read_Attributes_rsp>
[0x6a83:1] Manufacturer: None
[0x6a83:1] Model: None
Device 00:0d:6f:00:02:5d:75:49 already exists. Updating it.
device - 0x6a83:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: False
device - 0x6a83:00:0d:6f:00:02:5d:75:49 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 0x6a83:00:0d:6f:00:02:5d:75:49
[0x6a83](unk_model): started configuration
[0x6a83:ZDO](unk_model): 'async_configure' stage succeeded
[0x6a83] Extending timeout for 0x71 request
[0x6a83:1:0x0000]: bound 'basic' cluster: Status.TABLE_FULL
[0x6a83:1:0x0000]: finished channel configuration
[0x6a83] Extending timeout for 0x73 request
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=115 command_id=Command.Read_Attributes_rsp>
[0x6a83:1:0x0000]: 'async_configure' stage succeeded
[0x6a83](unk_model): completed configuration
[0x6a83](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790805.710695)
[0x6a83] Extending timeout for 0x75 request
[0x6a83:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=117 command_id=Command.Read_Attributes_rsp>
Device 0xf7aa (00:0d:6f:00:02:5d:75:49) joined the network
Device 00:0d:6f:00:02:5d:75:49 changed id (0x6a83 => 0xf7aa)
[0xf7aa] Cancelling old group rescan
[0xf7aa:zdo] ZDO request ZDOCmd.Device_annce: [0xF7AA, 00:0d:6f:00:02:5d:75:49, 128]
Ignoring message (b'14a0100201') on cluster 1280: unknown endpoint or cluster id: 'No cluster ID 0x0500 on (00:0d:6f:00:02:5d:75:49, 1)'
[0xf7aa] Extending timeout for 0x77 request
[0xf7aa:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=119 command_id=Command.Read_Attributes_rsp>
[0xf7aa] Extending timeout for 0x79 request
[0xf7aa:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=121 command_id=Command.Read_Attributes_rsp>
[0xf7aa] Extending timeout for 0x7b request
[0xf7aa:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=123 command_id=Command.Read_Attributes_rsp>
[0xf7aa:1] Manufacturer: None
[0xf7aa:1] Model: None
device - 0xf7aa:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: False
device - 0xf7aa:00:0d:6f:00:02:5d:75:49 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 0xf7aa:00:0d:6f:00:02:5d:75:49
[0xf7aa](unk_model): started configuration
[0xf7aa:ZDO](unk_model): 'async_configure' stage succeeded
Device 0xf7aa (00:0d:6f:00:02:5d:75:49) left the network
[0xf7aa] Extending timeout for 0x7d request
[0x0000:zdo] ZDO request ZDOCmd.IEEE_addr_req: [0xF7AA, 0, 0]
Device 0x7ece (00:0d:6f:00:02:5d:75:49) joined the network
Device 00:0d:6f:00:02:5d:75:49 changed id (0xf7aa => 0x7ece)
[0x7ece] Cancelling old group rescan
[0x7ece:zdo] ZDO request ZDOCmd.Device_annce: [0x7ECE, 00:0d:6f:00:02:5d:75:49, 128]
Ignoring message (b'14a0100301') on cluster 1280: unknown endpoint or cluster id: 'No cluster ID 0x0500 on (00:0d:6f:00:02:5d:75:49, 1)'
[0x7ece] Extending timeout for 0x7f request
[0x7ece](unk_model): started initialization
[0x7ece:ZDO](unk_model): 'async_initialize' stage succeeded
[0x7ece] Extending timeout for 0x81 request
[0x7ece:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=127 command_id=Command.Read_Attributes_rsp>
[0x7ece:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=129 command_id=Command.Read_Attributes_rsp>
[0x7ece] Extending timeout for 0x83 request
[0x7ece:1:0x0000]: initializing channel: from_cache: False
[0x7ece:1:0x0000]: 'async_initialize' stage succeeded
[0x7ece](unk_model): power source: Battery or Unknown
[0x7ece](unk_model): completed initialization
[0x7ece:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=131 command_id=Command.Read_Attributes_rsp>
[0x7ece] Extending timeout for 0x85 request
[0x7ece:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=133 command_id=Command.Read_Attributes_rsp>
[0x7ece:1] Manufacturer: None
[0x7ece:1] Model: None
Pairing log part 2 of 2
[0xd9b9:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=135 command_id=Command.Read_Attributes_rsp>
Device 0x7ece (00:0d:6f:00:02:5d:75:49) left the network
device - 0x7ece:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: False
device - 0x7ece:00:0d:6f:00:02:5d:75:49 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 0x7ece:00:0d:6f:00:02:5d:75:49
[0x7ece](unk_model): started configuration
[0x7ece:ZDO](unk_model): 'async_configure' stage succeeded
[0x7ece] Extending timeout for 0x8d request
[0x3cdc:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=137 command_id=Command.Read_Attributes_rsp>
[0xc36d:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=139 command_id=Command.Read_Attributes_rsp>
[0x7ece] Delivery error for seq # 0x7d, on endpoint id 0 cluster 0x0021: message send failure
[0x7ece:1:0x0000]: Failed to bind 'basic' cluster: [0x7ece:0:0x0021]: Message send failure
[0x7ece:1:0x0000]: finished channel configuration
[0x7ece] Extending timeout for 0x8f request
[0x0000:zdo] ZDO request ZDOCmd.IEEE_addr_req: [0x7ECE, 0, 0]
[0x120D](unk_model): Attempting to checkin with device - missed checkins: 2
[0x120d] Extending timeout for 0x91 request
[0x2c47:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=212 command_id=Command.Report_Attributes>
[0x2c47:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=18, value=<TypeValue type=int16s, value=2000>)]]
[0x2c47:1:0x0201] Attribute report received: occupied_heating_setpoint=2000
[0x2C47:1:0x0201]: Attribute report 'Thermostat'[occupied_heating_setpoint] = 2000
[0x2c47:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=213 command_id=Command.Report_Attributes>
[0x2c47:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=19, value=<TypeValue type=int16s, value=2600>)]]
[0x2c47:1:0x0201] Attribute report received: unoccupied_cooling_setpoint=2600
[0x2C47:1:0x0201]: Attribute report 'Thermostat'[unoccupied_cooling_setpoint] = 2600
[0x2c47:1:0x0202] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=214 command_id=Command.Report_Attributes>
[0x2c47:1:0x0202] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=enum8, value=enum8.undefined_0x05>)]]
[0x2c47:1:0x0202] Attribute report received: fan_mode=5
[0x2C47:1:0x0202]: Attribute report 'Fan Control'[fan_mode] = FanMode.Auto
climate.upstairs: Attribute 'occupied_heating_setpoint' = 2000 update
climate.upstairs: Attribute 'unoccupied_cooling_setpoint' = 2600 update
Device 0x74d0 (00:0d:6f:00:02:5d:75:49) joined the network
Device 00:0d:6f:00:02:5d:75:49 changed id (0x7ece => 0x74d0)
[0x74d0] Extending timeout for 0x96 request
[0x74d0:zdo] ZDO request ZDOCmd.Device_annce: [0x74D0, 00:0d:6f:00:02:5d:75:49, 128]
[0x74d0](unk_model): started initialization
[0x74d0:ZDO](unk_model): 'async_initialize' stage succeeded
[0x74d0] Extending timeout for 0x98 request
Ignoring message (b'14a0100401') on cluster 1280: unknown endpoint or cluster id: 'No cluster ID 0x0500 on (00:0d:6f:00:02:5d:75:49, 1)'
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=150 command_id=Command.Read_Attributes_rsp>
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=152 command_id=Command.Read_Attributes_rsp>
[0x74d0] Extending timeout for 0x9a request
[0x74d0:1:0x0000]: initializing channel: from_cache: False
[0x74d0:1:0x0000]: 'async_initialize' stage succeeded
[0x74d0](unk_model): power source: Battery or Unknown
[0x74d0](unk_model): completed initialization
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=154 command_id=Command.Read_Attributes_rsp>
[0x74d0] Extending timeout for 0x9c request
[0x74d0] Delivery error for seq # 0x8d, on endpoint id 0 cluster 0x0021: message send failure
[0x74d0:1:0x0000]: Failed to bind 'basic' cluster: [0x74d0:0:0x0021]: Message send failure
[0x74d0:1:0x0000]: finished channel configuration
[0x74d0] Extending timeout for 0x9e request
[0x74d0] Delivery error for seq # 0x8f, on endpoint id 1 cluster 0x0000: message send failure
[0x74d0:1:0x0000]: 'async_configure' stage succeeded
[0x74d0](unk_model): completed configuration
[0x74d0](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790834.7474263)
[0x74d0] Extending timeout for 0xa0 request
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=156 command_id=Command.Read_Attributes_rsp>
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=158 command_id=Command.Read_Attributes_rsp>
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=160 command_id=Command.Read_Attributes_rsp>
[0x74d0:1] Manufacturer: None
[0x74d0:1] Model: None
device - 0x74d0:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: False
device - 0x74d0:00:0d:6f:00:02:5d:75:49 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 0x74d0:00:0d:6f:00:02:5d:75:49
[0x74d0](unk_model): started configuration
[0x74d0:ZDO](unk_model): 'async_configure' stage succeeded
[0x74d0] Extending timeout for 0xa2 request
[0x74d0](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790835.373079)
[0x74d0] Extending timeout for 0xa4 request
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=164 command_id=Command.Read_Attributes_rsp>
[0x74d0:1:0x0000]: bound 'basic' cluster: Status.TABLE_FULL
[0x74d0] Extending timeout for 0xa6 request
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=166 command_id=Command.Read_Attributes_rsp>
[0x74d0](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790836.7431424)
[0x74d0] Extending timeout for 0xa8 request
[0x74d0:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=168 command_id=Command.Read_Attributes_rsp>
[0x120d] Delivery error for seq # 0x91, on endpoint id 1 cluster 0x0000: message send failure
[0xc36d:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=26 command_id=Command.Report_Attributes>
[0xc36d:1:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=Bool, value=Bool.false>)]]
[0xc36d:1:0x0006] Attribute report received: on_off=0
[0xc36d:1:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=27 command_id=Command.Report_Attributes>
[0xc36d:1:0x0008] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=0>)]]
[0xc36d:1:0x0008] Attribute report received: current_level=0
[0xC36D:1:0x0008]: received attribute: 0 update with value: 0
[0xc36d:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=28 command_id=Command.Report_Attributes>
[0xc36d:1:0x0b04] ZCL request 0x000a: [[Attribute(attrid=1291, value=<TypeValue type=int16s, value=0>)]]
[0xc36d:1:0x0b04] Attribute report received: active_power=0
Device 0x74d0 (00:0d:6f:00:02:5d:75:49) left the network
Device 0xefc7 (00:0d:6f:00:02:5d:75:49) joined the network
Device 00:0d:6f:00:02:5d:75:49 changed id (0x74d0 => 0xefc7)
[0xefc7] Extending timeout for 0xad request
[0xefc7:zdo] ZDO request ZDOCmd.Device_annce: [0xEFC7, 00:0d:6f:00:02:5d:75:49, 128]
Ignoring message (b'14a0100501') on cluster 1280: unknown endpoint or cluster id: 'No cluster ID 0x0500 on (00:0d:6f:00:02:5d:75:49, 1)'
[0xefc7](unk_model): started initialization
[0xefc7:ZDO](unk_model): 'async_initialize' stage succeeded
[0xefc7] Extending timeout for 0xaf request
[0xefc7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=173 command_id=Command.Read_Attributes_rsp>
[0xefc7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=175 command_id=Command.Read_Attributes_rsp>
[0xefc7] Extending timeout for 0xb1 request
[0xefc7:1:0x0000]: initializing channel: from_cache: False
[0xefc7:1:0x0000]: 'async_initialize' stage succeeded
[0xefc7](unk_model): power source: Battery or Unknown
[0xefc7](unk_model): completed initialization
[0xefc7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=177 command_id=Command.Read_Attributes_rsp>
[0xefc7] Extending timeout for 0xb3 request
[0xefc7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=179 command_id=Command.Read_Attributes_rsp>
[0xefc7:1] Manufacturer: None
[0xefc7:1] Model: None
device - 0xefc7:00:0d:6f:00:02:5d:75:49 entering async_device_initialized - is_new_join: False
device - 0xefc7:00:0d:6f:00:02:5d:75:49 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 0xefc7:00:0d:6f:00:02:5d:75:49
[0xefc7](unk_model): started configuration
[0xefc7:ZDO](unk_model): 'async_configure' stage succeeded
[0xefc7] Extending timeout for 0xb5 request
[0xefc7:1:0x0000]: bound 'basic' cluster: Status.TABLE_FULL
[0xefc7:1:0x0000]: finished channel configuration
[0xefc7] Extending timeout for 0xb7 request
[0xefc7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=183 command_id=Command.Read_Attributes_rsp>
[0xefc7:1:0x0000]: 'async_configure' stage succeeded
[0xefc7](unk_model): completed configuration
[0xefc7](unk_model): stored in registry: ZhaDeviceEntry(name='unk_manufacturer unk_model', ieee='00:0d:6f:00:02:5d:75:49', last_seen=1602790848.8034184)
[0xefc7] Extending timeout for 0xb9 request
Device 0xefc7 (00:0d:6f:00:02:5d:75:49) left the network
[0x2c47:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=215 command_id=Command.Report_Attributes>
[0x2c47:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=20, value=<TypeValue type=int16s, value=2000>)]]
[0x2c47:1:0x0201] Attribute report received: unoccupied_heating_setpoint=2000
[0x2C47:1:0x0201]: Attribute report 'Thermostat'[unoccupied_heating_setpoint] = 2000
[0x2c47:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=216 command_id=Command.Report_Attributes>
[0x2c47:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=28, value=<TypeValue type=enum8, value=enum8.undefined_0x03>)]]
[0x2c47:1:0x0201] Attribute report received: system_mode=3
[0x2C47:1:0x0201]: Attribute report 'Thermostat'[system_mode] = SystemMode.Cool
climate.upstairs: Attribute 'unoccupied_heating_setpoint' = 2000 update
climate.upstairs: Attribute 'system_mode' = SystemMode.Cool update
[0x3cdc:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=191 command_id=Command.Read_Attributes_rsp>
[0xd9b9:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=189 command_id=Command.Read_Attributes_rsp>
[0xc36d:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=193 command_id=Command.Read_Attributes_rsp>
[0xefc7] Delivery error for seq # 0xb9, on endpoint id 1 cluster 0x0000: message send failure
[0x5457:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=241 command_id=Command.Report_Attributes>
[0x5457:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=17, value=<TypeValue type=int16s, value=2278>)]]
[0x5457:1:0x0201] Attribute report received: occupied_cooling_setpoint=2278
[0x5457:1:0x0201]: Attribute report 'Thermostat'[occupied_cooling_setpoint] = 2278
[0x5457:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=242 command_id=Command.Report_Attributes>
[0x5457:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=18, value=<TypeValue type=int16s, value=2000>)]]
[0x5457:1:0x0201] Attribute report received: occupied_heating_setpoint=2000
[0x5457:1:0x0201]: Attribute report 'Thermostat'[occupied_heating_setpoint] = 2000
[0x5457:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=243 command_id=Command.Report_Attributes>
[0x5457:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=19, value=<TypeValue type=int16s, value=2600>)]]
[0x5457:1:0x0201] Attribute report received: unoccupied_cooling_setpoint=2600
[0x5457:1:0x0201]: Attribute report 'Thermostat'[unoccupied_cooling_setpoint] = 2600
[0x5457:1:0x0202] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=244 command_id=Command.Report_Attributes>
[0x5457:1:0x0202] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=enum8, value=enum8.undefined_0x05>)]]
[0x5457:1:0x0202] Attribute report received: fan_mode=5
[0x5457:1:0x0202]: Attribute report 'Fan Control'[fan_mode] = FanMode.Auto
climate.downstairs: Attribute 'occupied_cooling_setpoint' = 2278 update
climate.downstairs: Attribute 'occupied_heating_setpoint' = 2000 update
climate.downstairs: Attribute 'unoccupied_cooling_setpoint' = 2600 update
[0xefc7] Extending timeout for 0xc7 request
[0x5457:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=245 command_id=Command.Report_Attributes>
[0x5457:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=20, value=<TypeValue type=int16s, value=2000>)]]
[0x5457:1:0x0201] Attribute report received: unoccupied_heating_setpoint=2000
[0x5457:1:0x0201]: Attribute report 'Thermostat'[unoccupied_heating_setpoint] = 2000
climate.downstairs: Attribute 'unoccupied_heating_setpoint' = 2000 update
[0xefc7] Delivery error for seq # 0xc7, on endpoint id 1 cluster 0x0000: message send failure
[0x5457:1:0x0201] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=246 command_id=Command.Report_Attributes>
[0x5457:1:0x0201] ZCL request 0x000a: [[Attribute(attrid=2, value=<TypeValue type=bitmap8, value=bitmap8.0>)]]
[0x5457:1:0x0201] Attribute report received: occupancy=0
[0x5457:1:0x0201]: Attribute report 'Thermostat'[occupancy] = Occupancy.Unoccupied
climate.downstairs: Attribute 'occupancy' = Occupancy.Unoccupied update
[0xd9b9:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=203 command_id=Command.Read_Attributes_rsp>
[0x3cdc:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=205 command_id=Command.Read_Attributes_rsp>
[0xc36d:1:0x0b04] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=207 command_id=Command.Read_Attributes_rsp>
Are you sure the Xfinity devices are HA1.2 or Zigbee 3.0 compatible?
Zigbee is the communications technology and HA1.2 and zigbee 3.0 is the protocol which runs over the top.
Just because a device is a zigbee device does not necessarily mean it will run on HA.
The fact there are no clusters visible in the signature would indicate that to me.
I use the mct-340e sensors and they are great.
https://www.mydigitaldiscount.com/visonic-mct-340-e-wireless-door-window-temperature-sensor/
I also found 4 of the MCT-320 devices in the house we bought. Would be nice to be able to use them in HA. Is there any chance that support will be added? I mean, is it worth checking here from time to time?
I am surprised that the MCT-340 appears to work flawlessly. I would assume that when it’s the same manufacturer and even the model numbers are very similar, chances are that the protocol/communication is similar, too. So perhaps, it could be trivial to get these added?. But, of course, I could be totally wrong.
I don’t know how the process for integration of new hardware at HA works. Is there another forum I can submit this to, in order to “vote” for supporting these?
Actually no, your reasoning isn’t really correct. Visonic also manufactures for other systems that use zigbee as a communications technology but use a different messaging protocol. Also Visonic’s first efforts at Zigbee were not compliant.
Find a data sheet for the product, and look for HA1.2 or Zigbee3.0 on it. If it doesn’t state either of those two, it will not work with zigbee on HA.
@meremortal: Thank you so much, this is very helpful!
OK, I found a spec sheet saying this:
“2.4 GHz as per IEEE 802.15.4”
and
“Designed to comply with UL 639, ULC-S306, Title 47 CFR Part 15, IC RSS-210”
So, I guess no Zigbee3.0 or HA1.2 :frowning:
I found another page here that provides further support to your point:
https://community.smartthings.com/t/visonic-mct-320-from-xfinity/59544/2
Yes unfortunately, IEEE 802.15.4” is zigbee and 2.4ghz is the frequency range but I can’t find anything which indicates it will work with HA.
