Hi Mark,
I’ve taken a look through your log file and it’s mostly OK. It achieves powerlink OK etc etc.
I haven’t found anything that would indicate why you are having the problems, but I did find something else. The only issue that I’ve found is as follows:
From your log file
… Connects, downloads EEPROM and start Disarmed, everything looks OK to here …
20:17:38 A5 Message: Panel Status Arm Away - Exit Delay
20:18:08 A5 Message: Panel Status Armed Away
20:18:10 A7 Message: Panel Status Detail showing Armed Away with Fob 02
… perioidic A5 message updates as Armed Away …
20:22:51 A5 Message: Panel Status Armed Away
20:23:16 A7 Message: Panel Status Detail showing Disarmed with Fob 02
20:24:48 I haven’t had an A5 for a while so I ask the Panel for it’s Status
20:24:50 A5 Message: Panel Status Disarmed
What I expect to happen
I expect to receive A5 messages to determine panel status, the A7 message gives detailed information but only when in Powerlink mode so I tend to ignore these. When the Panel changes it’s status (Arming/Disarming and Zone Changes when sensors are triggered) the Panel sends me an A5 message without me requesting it. If nothing has happened in the Panel after a defined time, usually 90 senonds after the last transaction, then I request the Panel Status and the Panel sends me a series of A5 messages.
What your panel is doing
At 20:23:16 the A7 message should be preceeded by an A5 message that doesn’t happen with your panel. At 20:24:48 I haven’t had an A5 status for a while so my Component asks for it, this is what prompts the panel to send me the Disarmed status at 20:24:50. I don’t know why it didn’t send an A5 just before 20:23:16 when it sent the A7 message. In all other systems this is what I have seen.
What you see because of this
In the frontend it will show “Armed” until 20:24:50 even through you actually disarmed it at 20:23:16. So for a whole 94 seconds it showed the wrong panel state.
Maybe this is specific to your panel i.e. a “PowerMax Complete Part”. Or maybe not
Perhaps I need to look at using either the A5 or A7 message for the main panel state and not just the A5 as I can’t rely on the panel sending it promptly.
So, like I said at the start, your log file doesn’t indicate why you are having the problems you are having, sorry
