Vistapool Integration
I think I figured this out. You can change modes by writing to MBF_PAR_FILT_MODE the same way you did above, but using 1 for Auto (and 3 for Smart in my system, but Auto and Manual are just what I needed). Just for safety, in the Auto mode script I start by turning MANUAL_STATE Off in case it was running (I don’t know what the behavior would be if MANUAL_STATE is ON and FILT_MODE is also turned to 1) before switching FILT_MODE to 1. Seems to be working fine. Very convenient if you want to switch modes via Siri (for pool cleaning) etc. Now I need to figure out two things:
  • How to force a reading of the Modbus values right after changing modes (so they instantly reflect the change)
  • How to turn Manual/Auto selection scripts into a switch.
vistapool_manual_mode_on:
    - service: modbus.write_register
            hub: pool
            unit: 1
            address: 0x0411 # MBF_PAR_FILT_MODE (0 = Manual; 1 = Auto ; 3 = Smart)
            value: [0]
      data_template:
            hub: pool
            unit: 1
            address: 0x0413 # MBF_PAR_FILT_MANUAL_STATE (off = 0; on = 1)
            value: [1]
            hub: pool
            unit: 1
            address: 0x02F0 # MBF_SAVE_TO_EEPROM
            value: [1]
    - delay: 00:00:01
            hub: pool
            unit: 1
            address: 0x02F5    # MBF_EXEC
            value: [1]
vistapool_manual_mode_off:
            hub: pool
            unit: 1
            value: [0]
          data_template:
            hub: pool
            unit: 1
            value: [0]
            hub: pool
            unit: 1
            value: [1]
        - delay: 00:00:01
            hub: pool
            unit: 1
            value: [1]
vistapool_auto_mode:
          data_template:
            hub: pool
            unit: 1
            value: [0]
            hub: pool
            unit: 1
            value: [1]
            hub: pool
            unit: 1
            value: [1]
        - delay: 00:00:01
            hub: pool
            unit: 1
            value: [1]
How to force a reading of the Modbus values right after changing modes (so they instantly reflect the change)?
Make “scan_interval” shorter as possible but you will need to wait for modbus report (within this scan_interval) anyhow. Or “persuade” Vistapool device to instant reporting somehow.
How to turn Manual/Auto selection scripts into a switch?
Either switch template or create any selector and choose
Could you tell why do you need to switch Vistapool between Auto and Manual mode? I am just curious :wink: BTW good finding :+1:
Turns out homeassistant.update_entity service also works with modbus sensors, so calling the service instantly updates the state after the filtration mode change. This is the final script:
          data_template:
            hub: pool
            unit: 1
            value: [0]
            hub: pool
            unit: 1
            value: [1]
            hub: pool
            unit: 1
            value: [1]
        - delay: 00:00:01
            hub: pool
            unit: 1
            value: [1]
          data_template:
              entity_id: sensor. pool_filtration_mode
I ended up going the easy way. First I created a sensor template to reflect the state after executing any of the 3 scripts (Manual Mode Off, Manual Mode On and Auto; Smart is just there for fun):
    sensors:
      filtration:
        friendly_name: "Filtration Mode"
        value_template: >-
          {% if is_state('sensor. pool_filtration_mode', '0' ) and is_state('sensor. pool_filtration_manual_state', '0' ) %}
              MANUAL (OFF)
          {% elif is_state('sensor. pool_filtration_mode', '0' ) and is_state('sensor. pool_filtration_manual_state', '1' ) %}
              MANUAL (ON)
          {% elif is_state('sensor. pool_filtration_mode', '1' ) %}
              AUTO
          {% elif is_state('sensor. pool_filtration_mode', '3' ) %}
              SMART
And then I just call the script when I need to change modes:
Screenshot 2023-08-18 at 6.07.24 PM
I always have the system in Auto mode, but for pool bottom cleaning and backwash I need to turn it on and off manually. The device is not very easily accessible and Vistapool cloud connection is… well, a hit or miss. This saves some time and effort. Thanks!
here is the code of my nodered.
unfortunately I can only read out I am still looking for the white register of the boost mode and the setpiont of ph and redox
        "id": "618881f6ac67f894",
        "type": "tab",
        "label": "X valley",
        "disabled": false,
        "info": "",
        "env": []
        "id": "8540ac185c4f0b5c",
        "type": "modbus-read",
        "z": "618881f6ac67f894",
        "name": "",
        "topic": "",
        "showStatusActivities": false,
        "logIOActivities": false,
        "showErrors": false,
        "showWarnings": true,
        "unitid": "1",
        "dataType": "InputRegister",
        "adr": "258",
        "quantity": "1",
        "rate": "10",
        "rateUnit": "s",
        "delayOnStart": false,
        "startDelayTime": "",
        "server": "4a874db92373c071",
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "x": 250,
        "y": 220,
        "wires": [
                "eb7ef75e92679c2f"
        "id": "d45189fa80d3d138",
        "type": "comment",
        "name": "pH Waarde Zwembad (258)",
        "info": "",
        "x": 300,
        "y": 180,
        "wires": []
        "id": "5793be3be6a7dd43",
        "type": "debug",
        "name": "debug 4",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 960,
        "y": 100,
        "wires": []
        "id": "cf588a1fb85903b3",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "262",
        "quantity": "1",
        "rate": "500",
        "rateUnit": "ms",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 100,
        "wires": [
                "57cc04d605365961"
        "id": "57cc04d605365961",
        "type": "function",
        "name": "function 4",
        "func": "msg.payload = msg.payload / 10;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 100,
        "wires": [
                "5793be3be6a7dd43"
        "id": "dca10515cbd93b57",
        "type": "comment",
        "name": "Water Temperatuur Zwembad (262)",
        "info": "",
        "x": 320,
        "y": 60,
        "wires": []
        "id": "eb7ef75e92679c2f",
        "type": "function",
        "name": "function 5",
        "func": "msg.payload = msg.payload / 100;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 220,
        "wires": [
                "6bd9fc6ce913243a"
        "id": "8bb62b999eff31d9",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "259",
        "quantity": "1",
        "rate": "10",
        "rateUnit": "s",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 340,
        "wires": [
                "e924bfc049eebdef"
        "id": "532dcaf323292c93",
        "type": "comment",
        "name": "Rodux Sensor (259)",
        "info": "",
        "x": 270,
        "y": 300,
        "wires": []
        "id": "201cd07d0c2ca092",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "257",
        "quantity": "1",
        "rate": "10",
        "rateUnit": "s",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 460,
        "wires": [
                "855b18d3038c2974"
        "id": "5a2bfab46dca6801",
        "type": "comment",
        "name": "Hydrolysis (257)",
        "info": "",
        "x": 260,
        "y": 420,
        "wires": []
        "id": "855b18d3038c2974",
        "type": "function",
        "name": "function 6",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 580,
        "y": 460,
        "wires": [
                "1eaef61f7ae507dd"
        "id": "6bd9fc6ce913243a",
        "type": "openhab2-out2",
        "name": "",
        "controller": "6d29cbc8a3dbce62",
        "itemname": "Zwemspa_Sugar_Valley_PH",
        "topic": "ItemUpdate",
        "payload": "",
        "onlywhenchanged": false,
        "x": 1020,
        "y": 220,
        "wires": [
        "id": "e924bfc049eebdef",
        "name": "",
        "itemname": "Zwemspa_Sugar_Valley_Rodux",
        "payload": "",
        "x": 1030,
        "y": 340,
        "wires": [
        "id": "1eaef61f7ae507dd",
        "name": "",
        "itemname": "Zwemspa_Sugar_Valley_Hydrolysis",
        "payload": "",
        "x": 1040,
        "y": 460,
        "wires": [
        "id": "8f5bcd6107c34e12",
        "type": "comment",
        "name": "Pool Target PH (1284)",
        "info": "",
        "x": 280,
        "y": 620,
        "wires": []
        "id": "7ef11bb47471170c",
        "type": "comment",
        "name": "Pool Target Redox (1288)",
        "info": "",
        "x": 290,
        "y": 760,
        "wires": []
        "id": "2e3d0e9dd3ebed73",
        "type": "comment",
        "name": "Pool Filtration (1057)",
        "info": "",
        "x": 270,
        "y": 860,
        "wires": []
        "id": "933ce1153517a269",
        "type": "comment",
        "name": "Pool Filtration mode (1041)",
        "info": "",
        "x": 290,
        "y": 980,
        "wires": []
        "id": "01e94f6f2bfd0cab",
        "type": "debug",
        "name": "debug 11",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 980,
        "y": 660,
        "wires": []
        "id": "a0e76710700e84fa",
        "name": "",
        "topic": "",
        "unitid": "1",
        "dataType": "HoldingRegister",
        "adr": "1284",
        "quantity": "1",
        "rate": "500",
        "rateUnit": "ms",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 660,
        "wires": [
                "723055f85d83ac73"
        "id": "723055f85d83ac73",
        "type": "function",
        "name": "function 35",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 590,
        "y": 660,
        "wires": [
                "01e94f6f2bfd0cab"
        "id": "960ae8868fffdaad",
        "type": "debug",
        "name": "debug 12",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 980,
        "y": 800,
        "wires": []
        "id": "e1f222950981c090",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "1288",
        "quantity": "1",
        "rate": "500",
        "rateUnit": "ms",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 800,
        "wires": [
                "960ae8868fffdaad"
        "id": "1424f8d71512dd56",
        "type": "debug",
        "name": "debug 13",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1000,
        "y": 900,
        "wires": []
        "id": "48c8116905002b2f",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "1057",
        "quantity": "1",
        "rate": "500",
        "rateUnit": "ms",
        "useIOFile": false,
        "ioFile": "",
        "x": 250,
        "y": 900,
        "wires": [
                "1424f8d71512dd56"
        "id": "ab076dab24091524",
        "type": "debug",
        "name": "debug 14",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1000,
        "y": 1020,
        "wires": []
        "id": "e92fb0055f7b6121",
        "name": "",
        "topic": "",
        "unitid": "1",
        "adr": "1041",
        "quantity": "1",
        "rate": "500",
        "rateUnit": "ms",
        "useIOFile": false,
        "ioFile": "",
        "x": 270,
        "y": 1020,
        "wires": [
                "ab076dab24091524"
        "id": "4a874db92373c071",
        "type": "modbus-client",
        "name": "x valley sugar modbus RS485",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "failureLogEnabled": true,
        "tcpHost": "192.168.2.220",
        "tcpPort": "8899",
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": "9600",
        "serialDatabits": "8",
        "serialStopbits": "1",
        "serialParity": "none",
        "serialConnectionDelay": "100",
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": "1",
        "commandDelay": "1",
        "clientTimeout": "1000",
        "reconnectOnTimeout": true,
        "reconnectTimeout": "2000",
        "parallelUnitIdsAllowed": true,
        "showLogs": true
        "id": "6d29cbc8a3dbce62",
        "type": "openhab2-controller2",
        "name": "Openhab 3",
        "protocol": "http",
        "host": "localhost",
        "port": "8080",
        "path": "",
        "username": "",
        "password": "",
        "ohversion": "v3",
        "token": ""
Hi Guys,
Small problem/ question.
After my upgrade to HA core-2023.9.0 I have problems with my modbus setup, I don’t get any info from my Oxilife 2 anymore! My EW11 is perfectly reachable, and he says he is connected to HA and is sending and receiving data!
And in my log I see following error:
Logger: homeassistant.components.modbus.modbus
Source: components/modbus/modbus.py:401
Integration: Modbus (documentation, issues)
First occurred: 10:58:44 (1 occurrences)
Last logged: 10:58:44
Pymodbus: EW11: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
Any idea?
regards,
 Jurgen
You might try this
Done, but the success was temporary, 2 minutes! :wink:
Again no data anymore.
I also managed to successfully connect my Sugar Valley Oxilife 2 to my Home Asssitant. There was a question in this thread whether the Oxilife can supply power to the ModBus/RS485 interface device. I measured it and tried it out and can confirm that this is possible. So here is my set-up:
As ModBus/RS485 interface device I’m using the HF5111S from hi-flying.com, here is the overview of their serial server devices: Ethernet Serial Server. You’ll find this in the internet for around 33,-€ incl. shipping:
This one is connected to the EXTERN connector on the Oxilife motherboard:
in the following way:
Oxilife_ModBus_Connection
Before doing that I measured the power consumption of the HF5111S, it turned out to consume 35mA, which I assumed can easily be delivered by the Oxilife:
So I’m powering the HF5111S from the Oxilife and it works flawlessly since weeks.
In Home Assistant I’m using the following configuration in configuration.yaml:
modbus:
  - name: Oxilife
    type: tcp
    host: 192.168.188.62
    port: 8899
    sensors:
      - name: Oxilife-ModBus-ph
        input_type: input
        unit_of_measurement: mol/l
        data_type: uint16
        slave: 1
        address: 258
        unique_id: Oxilife-ModBus-pH
        scale: .01
        offset: 0
      - name: Oxilife-ModBus-rx
        input_type: input
        unit_of_measurement: mV
        data_type: uint16
        slave: 1
        address: 259
        unique_id: Oxilife-ModBus-rx
        scale: 1
        offset: 0
      - name: Oxilife-ModBus-wt
        input_type: input
        unit_of_measurement: Celsius
        data_type: uint16
        slave: 1
        address: 262
        unique_id: Oxilife-ModBus-wt
        scale: .1
        offset: 0
And then I built some simple gauges to be able to monitor the main pool parameters from any mobile device in the house:
The YAML of the three gauges is as follows:
type: gauge
entity: sensor.oxilife_modbus_wt
needle: true
min: 0
max: 38
segments:
    color: '#43a047'
    color: '#ffa600'
    color: '#db4437'
severity:
  green: 0
  yellow: 0
  red: 0
name: Wasser Temperatur
unit: °C
type: gauge
entity: sensor.oxilife_modbus_ph
needle: true
min: 6.8
max: 7.8
segments:
    color: '#db4437'
    color: '#ffa600'
    color: '#43a047'
    color: '#ffa600'
    color: '#db4437'
unit: ' '
type: gauge
entity: sensor.oxilife_modbus_rx
needle: true
min: 500
max: 900
segments:
    color: '#db4437'
    color: '#ffa600'
    color: '#43a047'
    color: '#ffa600'
    color: '#db4437'
unit: ' mV'
severity:
  green: 0
  yellow: 0
  red: 0
Simple and intuitive so every family member can easily interpret the values. :slight_smile:
Hi thank you . Could you write me a description of the HF settings. It was necessary to set something in HF.
Sure! Here we go, the settings in the web interface of the HF5111S:
System Settings
Serial Port Settings
Communication Settings
Thanks , I will try if I buy HF. Thanks
Amazing Thonglor, and thank you for sharing!
Where did you buy the connector attached to modbus 3 port?
Best regards,
J
In Ebay you’ll find a lot of sellers for this device, it’s always between 32,-€ and 36,-€ incl. shipping.
IMG_0349
I mean this connector…
This is a standard 2.54mm 5-pin PCB female connector, e.g. like sold here:
(I didn’t buy it, I had it lying around at home)
Many thanks,
Have a great weekend!
Hello… can you give me the repository to find in HACS, I have added a folder in components but I don’t get integration. Thank you
This is not in HACS, you need to set it up manually as described above
Correct… I have uploaded the folders and put them in components, restarted and when I go to add it does not appear in integrations… any ideas? Thank you
