Visual editor is not supported for this configuration:
Home Assistant 2023.10.0
Supervisor 2023.10.0
Operating System 10.5
Frontend 20231002.0 - latest
I’m pretty sure that since updating to this version, the Visual Editor for the “power-flow-card-plus” and “energy-flow-card-plus” cards is no longer presented either when editing an existing card or when inserting a new one.
This is what I am seeing,
Capture
Not sure what “_a.entries” is, but it’s not present anywhere in the YAML code for the card.
You may be best off connecting with the card author on Github: Issues · flixlix/power-flow-card-plus · GitHub
Im experiencing exactly the same, also seeing it in the atomic calendar card
Also noticed this on the Atomic calendar card, same error:
Home Assistant 2023.10.3
Operating System 11.0
Frontend 20231005.0 - latest
In most cases this seems like a wrong user’s code.
Could you possibly elaborate on how to resolve this issue please?
Better to ask this particular custom card’s author.
As soon as you use any option in yaml that is not supported by the card’s visual editor, you will get that warning. There’s nothing to fix here on the users side unless you remove the unsupported property, but that will most likely change your desired behavior. This is how dashboards work in general. The UI only supports basic configurations, as soon as you add advanced options, only yaml is available.
If you want all the options to be supported for your card, then you have to make a request to the author who made the custom card to support said feature in the UI.
Any luck with this issue ?
I´m suddenly experiences the same issue - It has been working perfectly fine previously.
Hi, welcome to the community. This is not a bug, please read my last response. It covers what your options are.
Makes sense, thank you for the response, appreciate
