Visual group editor
Hello!
does anybody know if it is possible to visually alter a certain entity right from the frontend? this is the use case: all my window covers are grouped under the group covers. This works most of the time, but when I have gusts staying over, I don’t want to automatically command the cover in their room.
Could I visually display a certain group, and toggle on and off the entities that comprise that group?
thanks
There’s no standard card for that.
An alternative would be to use an input_boolean to indicate when a guest is present and then have an automation remove/add the guest room’s cover from the group based on the input_boolean’s on/off state.
However, the group would need to be a YAML-based (“old-style”) group and not a Cover Group (like the kind created using the Helpers menu) because (currently) there’s no service call to manage the membership of groups created via the Helpers menu.
Oh damn :frowning:
thanks however for your detailed information!!
