Visual Studio Code Icons
I’ve installed VS Code on my HA instance, and while everything seems to be working as expected, I can’t see any icons in the application.
Does anyone have an idea what might be causing this issue?
Thanks in advance for your help! :blush:
Extensions you should install:
vscode-icons
Home Assistant Config Helper (though this can also be a PITA)
Material Design Icons Intelisense
UUID Generator (for unique ids)
indent-rainbow (will help spot indentation errors).
