this is my first request for help in this forum, I hope this is the right place and somebody can show me an obvious solution. The problem I’m facing since some updates ago is that the really wonderful VSCode addon puts colourful syntax warnings after some yaml rows. Related features work fine. What am I possibly doing wrong?
Style is not a valid option for the entities card. If you are using card-mod, like all custom cards, this is not included in the extension syntax schema. Also if this is card-mod you need to update how style is used.
Confirmation dialogue should only be used under the tap_action option.
Ok, thanks anyway, I’ll postpone this problem until I start to understand better what I’m writing More critical is that confirmation dialog does not appear because I can power off the flat accidentally with one touch. But for this I plan to use two parallel IP relays.
