Visual studio code yaml syntax checker
in the previous month I experienced some error messages while editing my config.yaml and other files.
these messages were untrue and after some searching in this community it appeared to be the yaml syntax checkerto be the culprit. the work around was to downgrade the syntax checker to a lower version.
I removed the syntax checker completely and forgot about it.
now I like to install the syntax checker but I completely forgot the name of the tool and I can’t find the post saying to downgrade.
can anyone give a hint to the right direction?
thanks
Just search for home assistant in extensions. It’s the only one with that name and logo. IIRC it’s Home Assistant Config Helper or something like that.
