Visualize Your Smart Home in 3D — Powered by Zircon3D and Home Assistant
Visualize Your Smart Home, Floor by Floor
Zircon3D transforms your smart home into an interactive 3D experience. From full-building models to detailed floorplans, you can explore your space, room by room. Monitor temperature, humidity, and motion through dynamic sensor heatmaps, and control lights, plugs, and other devices directly on the 3D layout. It’s not just a dashboard — it’s a digital twin of your home, built for visibility, control, and insight.
Built as a Home Assistant Add-on: Zircon3D Proxy
Zircon3D integrates seamlessly with Home Assistant through its add-on, Zircon3D Proxy.
It reads data from your devices and presents them in a living, breathing 3D model — generated from your own floorplan. Whether it’s viewing current temperatures, toggling lights, or spotting patterns in your living environment, Zircon3D gives you a whole new way to interact with your home.
And because it’s designed with performance in mind, it works both in the cloud and on low-powered hardware — even a Home Assistant OS install.
OEM, Integrations, and White-Label Support
Looking to integrate 3D visualization into your platform or product?
Zircon3D supports OEM deployment and custom integration. Whether you’re building a smart building platform, a facility management tool, or a localized IoT solution, Zircon3D can bring your data to life — in a modern, intuitive, visual way.
It’s easy to embed, lightweight to deploy, and designed to adapt.
Contact us today at https://zircon3d.com — and start visualizing your data in 3D.
