Vizio Integration - Show apps
I have been using the integration with Vizio (https://www.home-assistant.io/integrations/vizio)
and would request the ability to launch TV apps from homeassistant
The latest release of pyvizio has these methods:
pyvizio --ip={ip:port} --device_type={device_type} --auth={auth_code} get-apps-list
pyvizio --ip={ip:port} --device_type={device_type} --auth={auth_code} get-current-app
pyvizio --ip={ip:port} --device_type={device_type} --auth={auth_code} launch-app "{app_name}"
I could then make automations to launch a certain app (Netflix)
@raman325 I’ve seen some commits into the vizio component. Thanks for improving it :slight_smile: Is it possible to get Vizio apps to launch (Netflix, Prime Video, YoutubeTV, etc) into the integration, too ?
Hi @veep60 I added app launching support to pyvizio with the intention to add it to HA :slight_smile: . Currently waiting for my other PR to get reviewed and approved to minimize the number of changes in flight at a time: https://github.com/home-assistant/home-assistant/pull/31520
@veep60 the change to add support for apps was just merged so it will either come out in the upcoming release or the one after that depending on timing
yes thanks so much! I will follow the release notes of HA to see when it makes it into the newer builds. I cannot wait to try it out at home. I have some cool ideas for automation :slight_smile:
