Vizio TV toggles between unavailable and off
My TV is doing this strange thing where it continuously loses connection. I have tried rebooting the TV and doing a power cycle + factory reset with the same results. I get these results whether I use the cast integration or the Vizio TV integration. I don’t get this result if I just hook up a chromecast as opposed to using Vizio’s built in smart cast. Has anyone had a similar experience? HassOS 3.13.
I am also experiencing the same. Did you find anything??
Any updates here? Anyone for help?
This seems to be happening with numerous device integrations at the moment
So does it seem to be an Home Assistant issue? I thought it’s Vizio since it’s only happening for this device for me. Which ones you facing this issue?
My log for the last few days is filled with thousands of these from Shelly integration
I have only seen this with my Vizio TV and no other integration. But yeah I don’t use any Shelly so not sure if its some integrations specific… :frowning:
Hi. I have this same issue on my Vizio P 75-C1. When it is turned off, it shows “unavailable”. I want to be able to turn it on and set it to a specific input via script (node-red) via Alexa instructions.
