Good evening everyone,
I recently used my second ESP8266 ever to monitor the water level in my coffee machine (somehow duplicating the work already being discussed here and here, which I only found out now trying to solve my error message)…
The goal:
Use VL53L0X Time of flight-sensor to measure distance to water level in tank, do some first filtering/smooth the values sent to HA (where the conversion to % fill level is done); at the same time flash an LED if the water level drops below a certain level (i.e. the distance is greater than 0,22m), in order to notify me also “offline”.
The code currently used (please excuse the code quality, it’s only my no2^^):
substitutions:
friendly_name: Espressomaschine Füllstand
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable OTA updater
ota:
password: ******************
# Define WiFi credentials
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp8266-Espressotank"
# Enable backup http web portal
captive_portal:
# Enable I²C bus
i2c:
sda: 4
scl: 5
text_sensor:
# Send IP Address
- platform: wifi_info
ip_address:
name: $friendly_name IP-Addresse
# Send Uptime in raw seconds
icon: mdi:clock-start
# Define LED as output
output:
- platform: gpio
pin: GPIO13
# Send WiFi signal strength & uptime to HA
- platform: wifi_signal
name: $friendly_name WLAN-Signal
update_interval: 60s
# Convert uptime into human readable string
- platform: uptime
on_raw_value:
then:
- text_sensor.template.publish:
# Custom C++ code to generate the result
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# Integrate VL53L0X Time Of Flight Distance Sensor
- platform: vl53l0x
update_interval: 3s
unit_of_measurement: "m"
icon: "mdi:waves-arrow-up"
state_class: "measurement"
timeout: 100ms
accuracy_decimals: 3
filters:
- median:
window_size: 11
send_every: 1
send_first_at: 1
on_value:
then:
- if:
condition:
sensor.in_range:
above: 0.22
then:
- output.turn_on: gpio_d7
- delay: 500ms
- output.turn_off: gpio_d7
- delay: 500ms
- delay: 500ms
- delay: 500ms
- delay: 500ms
switch:
# Expose an ESP8266 restart button to HA
- platform: restart
name: "Neustart ESP8266 Espressotank"
The problem:
After some time (can be immediately after boot-up of ESP8266, can be after veeery long, can sometimes be triggered by moving the sensor around, i.e. creating wildly changing sensor readings), the proper sensor readings stop with error message
[01:05:04][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:05:04][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
Full log of a typical runtime:
INFO Reading configuration /config/esphome/esp8266-espressotank.yaml...
INFO Starting log output from esp8266-espressotank.local using esphome API
INFO Successfully connected to esp8266-espressotank.local
[00:34:04][D][api.connection:861]: Home Assistant 2022.7.6 (###.###.###.###): Connected successfully
[00:34:04][I][app:102]: ESPHome version 2022.6.2 compiled on Jul 22 2022, 17:18:08
[00:34:04][C][wifi:491]: WiFi:
[00:34:04][C][wifi:353]: Local MAC: ##:##:##:##:##:##
[00:34:04][C][wifi:354]: SSID: 'secret_SSID'
[00:34:04][C][wifi:355]: IP Address: ###.###.###.###
[00:34:04][C][wifi:356]: BSSID: ##:##:##:##:##:##
[00:34:04][C][wifi:358]: Hostname: 'esp8266-espressotank'
[00:34:04][C][wifi:360]: Signal strength: -59 dB ▂▄▆█
[00:34:04][C][wifi:364]: Channel: 1
[00:34:04][C][wifi:365]: Subnet: ###.###.###.###
[00:34:04][C][wifi:366]: Gateway: ###.###.###.###
[00:34:04][C][wifi:367]: DNS1: ###.###.###.###
[00:34:04][C][wifi:368]: DNS2: ###.###.###.###
[00:34:04][C][logger:275]: Logger:
[00:34:04][C][logger:276]: Level: DEBUG
[00:34:04][C][logger:277]: Log Baud Rate: 115200
[00:34:04][C][logger:278]: Hardware UART: UART0
[00:34:04][C][i2c.arduino:038]: I2C Bus:
[00:34:04][C][i2c.arduino:039]: SDA Pin: GPIO4
[00:34:04][C][i2c.arduino:040]: SCL Pin: GPIO5
[00:34:04][C][i2c.arduino:041]: Frequency: 50000 Hz
[00:34:04][C][i2c.arduino:044]: Recovery: bus successfully recovered
[00:34:04][I][i2c.arduino:054]: Results from i2c bus scan:
[00:34:04][I][i2c.arduino:060]: Found i2c device at address 0x29
[00:34:04][C][template.text_sensor:021]: Template Sensor 'Espressomaschine Füllstand Uptime'
[00:34:04][C][template.text_sensor:021]: Icon: 'mdi:clock-start'
[00:34:05][C][gpio.output:010]: GPIO Binary Output:
[00:34:05][C][gpio.output:011]: Pin: GPIO13
[00:34:05][C][uptime.sensor:031]: Uptime Sensor 'Espressomaschine Füllstand Uptime'
[00:34:05][C][uptime.sensor:031]: State Class: 'total_increasing'
[00:34:05][C][uptime.sensor:031]: Unit of Measurement: 's'
[00:34:05][C][uptime.sensor:031]: Accuracy Decimals: 0
[00:34:05][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[00:34:05][C][vl53l0x:024]: VL53L0X 'Espressomaschine Füllstand Distanz'
[00:34:05][C][vl53l0x:024]: State Class: 'measurement'
[00:34:05][C][vl53l0x:024]: Unit of Measurement: 'm'
[00:34:05][C][vl53l0x:024]: Accuracy Decimals: 3
[00:34:05][C][vl53l0x:024]: Icon: 'mdi:waves-arrow-up'
[00:34:05][C][vl53l0x:025]: Update Interval: 3.0s
[00:34:05][C][vl53l0x:026]: Address: 0x29
[00:34:05][C][vl53l0x:030]: Timeout: 10000us
[00:34:05][C][restart:022]: Restart Switch 'Neustart ESP8266 Espressotank'
[00:34:05][C][restart:022]: Icon: 'mdi:restart'
[00:34:05][C][captive_portal:088]: Captive Portal:
[00:34:05][C][mdns:084]: mDNS:
[00:34:05][C][mdns:085]: Hostname: esp8266-espressotank
[00:34:05][C][ota:085]: Over-The-Air Updates:
[00:34:05][C][ota:086]: Address: esp8266-espressotank.local:8266
[00:34:05][C][ota:089]: Using Password.
[00:34:05][C][api:138]: API Server:
[00:34:05][C][api:139]: Address: esp8266-espressotank.local:6053
[00:34:05][C][api:143]: Using noise encryption: NO
[00:34:05][C][wifi_info:009]: WifiInfo IPAddress 'Espressomaschine Füllstand IP-Addresse'
[00:34:05][C][wifi_signal.sensor:009]: WiFi Signal 'Espressomaschine Füllstand WLAN-Signal'
[00:34:05][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[00:34:05][C][wifi_signal.sensor:009]: State Class: 'measurement'
[00:34:05][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[00:34:05][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[00:34:06][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.104 m
[00:34:06][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.10400 m with 3 decimals of accuracy
[00:34:09][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.101 m
[00:34:09][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.10100 m with 3 decimals of accuracy
[00:34:12][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.097 m
[00:34:12][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09700 m with 3 decimals of accuracy
[00:34:15][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.098 m
[00:34:15][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09800 m with 3 decimals of accuracy
[00:34:18][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.098 m
[00:34:18][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09800 m with 3 decimals of accuracy
[00:34:21][D][vl53l0x:264]: 'Espressomaschine Füllstand Distanz' - Got distance 0.102 m
[00:34:21][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.10200 m with 3 decimals of accuracy
[01:04:31][D][vl53l0x:308]: 'Espressomaschine Füllstand Distanz' - Got distance 0.100 m
[01:04:31][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.10000 m with 3 decimals of accuracy
[01:04:34][D][vl53l0x:308]: 'Espressomaschine Füllstand Distanz' - Got distance 0.098 m
[01:04:34][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09800 m with 3 decimals of accuracy
[01:04:37][D][vl53l0x:308]: 'Espressomaschine Füllstand Distanz' - Got distance 0.099 m
[01:04:37][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09900 m with 3 decimals of accuracy
[01:04:40][D][vl53l0x:308]: 'Espressomaschine Füllstand Distanz' - Got distance 0.096 m
[01:04:40][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state 0.09600 m with 3 decimals of accuracy
[01:04:46][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:04:46][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
[01:04:49][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:04:49][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
[01:04:52][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:04:52][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
[01:04:55][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:04:55][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
[01:04:57][D][text_sensor:067]: 'Espressomaschine Füllstand Uptime': Sending state '26m 44s'
[01:04:57][D][sensor:124]: 'Espressomaschine Füllstand Uptime': Sending state 1603.89600 s with 0 decimals of accuracy
[01:04:58][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:04:58][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
[01:05:01][D][sensor:124]: 'Espressomaschine Füllstand Distanz': Sending state nan m with 3 decimals of accuracy
[01:05:01][W][vl53l0x:264]: Espressomaschine Füllstand Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
Any ideas, anyone?
I realize that there seems to be one dropped measurement (between time codes 01:04:40 and 01:04:46 in the log, usually only 3secs) - but honestly have neither a clue why, nor where to start digging.
I already experimented with the timeout-parameter (<> 100ms, disabled the filter, also disabled the LED-/GPIO-toggle…), with no success.
I also found this approach to convert nan-values here, which would be acceptable if my sensor would not give 100% nan-readings once it got off the rails…^^
(A bit off-topic, I’d also appreciate hints toward a more elegant way to implement the LED flashing if distance > threshold).
Thanks a lot in advance!
, and ii) I wanted to hand over one or two of these tank level sensors (then with flashing LEDs as indicator, see my initial YAML above) to other espresso machine owners, who don’t run ESPhome/HomeAssistant - so this restart-route would not be an option for them…
