garmcqui
(Gareth)
November 5, 2021, 5:08pm
1
Hi all, am trying to make a level sensor for an oil tank using an ESP-07 (ESP-8266 based) and a VL53L1X time of flight ranging module. This is the sensor:
I have managed to get the sensor working using Arduino IDE, but I want to get it working with ESPhome, so I can use it with Home Assistant.
substitutions:
devicename: oil-tank-sensor
friendly_devicename: oil-tank
esphome:
platform: esp8266
board: esp07
wifi:
ssid: "SSID"
password: "WifiPASSWORD"
captive_portal:
mqtt:
broker: 192.168.1.163
username: XXXX
password: XXXX!
discovery: true
discovery_retain: true
# Enable logging
logger:
level: DEBUG
#level: INFO
i2c:
sda: 04
scl: 05
scan: true
binary_sensor:
- platform: status
- platform: vl53l1x
name: "Oil Distance"
timing_budget: 50ms
update_interval: 0.1s
distance_mode: long
address: 0x29
- platform: wifi_signal
name: $friendly_devicename signal strength
switch:
- platform: restart
name: "Oil Sensor Restart"
When I validate, I get the following:
Am i right in thinking the VL53L1X is supported?
Any advice appreciated. Thanks,
G
Hellis81
(Hellis81)
November 5, 2021, 5:55pm
2
garmcqui
(Gareth)
November 6, 2021, 10:51am
3
Thanks Hellis81, after some tinkering and setting up the custom component and custom sensor etc, it is working now. Thanks so much.
One other thing I would like to do - as the chip and sensor will be powered from a 3.6v lithium battery, I am using the deep sleep function so that it is only powered up for 20sec every hour. To avoid having to power the sensor continually, I am using a 2N222 transistor as a switch to power on the sensor. To do this, I need to set pin GPIO15 high when it wakes from deep sleep.
In Arduino, I used this successfully:
pinMode(15,OUTPUT);
digitalWrite(15,HIGH);
But what is the simplest way to do this in ESPhome?
Thanks,
Gareth
Hellis81
(Hellis81)
November 6, 2021, 12:31pm
4
A switch, with ALWAYS_ON.
GPIO Switch — ESPHome
I think
garmcqui
(Gareth)
March 31, 2022, 3:02pm
5
Hi, thanks to Hellis81, this has been working great over the past 5 months. I had to use the custom component at GitHub - jardous/tof_vl53l1x: ESPHome custom sensor utilizing the VL53L1X Time of Flight distance module
However, something has happened recently (not sure if it was an update to HA, ESPHome or something else, but now the code won’t compile and install.
Here is my code:
substitutions:
devicename: oiltank-sensor
friendly_devicename: oiltank
esphome:
platform: esp8266
board: esp07
includes:
- tof_vl53l1x.h
libraries:
- "VL53L1x"
switch:
- platform: gpio
pin: 15
name: $friendly_devicename Sensor On
restore_mode: always_on
- platform: restart
wifi:
fast_connect: true
ssid: "XXXX"
password: "XXXXXX"
# No API when using battery
# api:
#captive_portal:
mqtt:
username: XXXX
password: XXXXX
discovery: true
# Enable logging
logger:
level: DEBUG
i2c:
sda: 04
scl: 05
scan: true
binary_sensor:
- platform: status
- platform: custom
lambda: |-
auto my_sensor = new MyCustomSensor();
App.register_component(my_sensor);
return {my_sensor};
sensors:
- name: $friendly_devicename Distance
accuracy_decimals: 0
unit_of_measurement: "mm"
However, here is the log when I try to build:
Processing oiltank-sensor (board: esp07; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|-- <VL53L1X> 1.3.1
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <AsyncMqttClient-esphome> 0.8.6
|-- <Wire> 1.0
|-- <ArduinoJson> 6.18.5
Compiling /data/oiltank-sensor/.pioenvs/oiltank-sensor/src/main.cpp.o
In file included from src/main.cpp:49:
src/tof_vl53l1x.h:496:10: warning: missing terminating ' character
496 | <!-- '"` --><!-- </textarea></xmp> --></option></form><form class="js-site-search-form" role="search" aria-label="Site" data-scope-type="Repository" data-scope-id="193980322" data-scoped-search-url="/jardous/tof_vl53l1x/search" data-owner-scoped-search-url="/users/jardous/search" data-unscoped-search-url="/search" action="/jardous/tof_vl53l1x/search" accept-charset="UTF-8" method="get">
src/tof_vl53l1x.h:496:10: error: missing terminating ' character
src/tof_vl53l1x.h:553:75: error: extended character ↵ is not valid in an identifier
553 | <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:558:56: error: extended character ↵ is not valid in an identifier
558 | <span class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:600:75: error: extended character ↵ is not valid in an identifier
600 | <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:605:56: error: extended character ↵ is not valid in an identifier
605 | <span class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:638:75: error: extended character ↵ is not valid in an identifier
638 | <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:643:56: error: extended character ↵ is not valid in an identifier
643 | <span class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:676:75: error: extended character ↵ is not valid in an identifier
676 | <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:681:56: error: extended character ↵ is not valid in an identifier
681 | <span class="d-inline-block ml-1 v-align-middle">↵</span>
src/tof_vl53l1x.h:1056:25: warning: missing terminating " character
1056 | data-action="
src/tof_vl53l1x.h:1056:25: error: missing terminating " character
src/tof_vl53l1x.h:1057:41: error: stray '#' in program
1057 | input-entered:ref-selector#inputEntered
src/tof_vl53l1x.h:1058:40: error: stray '#' in program
1058 | tab-selected:ref-selector#tabSelected
src/tof_vl53l1x.h:1059:38: error: stray '#' in program
1059 | focus-list:ref-selector#focusFirstListMember
src/tof_vl53l1x.h:1060:13: warning: missing terminating " character
1060 | "
src/tof_vl53l1x.h:1060:13: error: missing terminating " character
src/tof_vl53l1x.h:1079:80: warning: missing terminating ' character
1079 | <!-- TODO: this max-height is necessary or else the branch list won't scroll. why? -->
src/tof_vl53l1x.h:1079:80: error: missing terminating ' character
src/tof_vl53l1x.h:1108:25: warning: missing terminating " character
1108 | data-action="
src/tof_vl53l1x.h:1108:25: error: missing terminating " character
src/tof_vl53l1x.h:1109:41: error: stray '#' in program
1109 | input-entered:ref-selector#inputEntered
src/tof_vl53l1x.h:1110:40: error: stray '#' in program
1110 | tab-selected:ref-selector#tabSelected
src/tof_vl53l1x.h:1111:38: error: stray '#' in program
1111 | focus-list:ref-selector#focusFirstListMember
src/tof_vl53l1x.h:1112:13: warning: missing terminating " character
1112 | "
src/tof_vl53l1x.h:1112:13: error: missing terminating " character
src/tof_vl53l1x.h:1409:71: error: stray '#' in program
1409 | <td id="LC1" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds">"</span>esphome.h<span class="pl-pds">"</span></span></td>
src/tof_vl53l1x.h:1418:71: error: stray '#' in program
1418 | <td id="LC3" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds"><</span>Wire.h<span class="pl-pds">></span></span></td>
src/tof_vl53l1x.h:1422:71: error: stray '#' in program
1422 | <td id="LC4" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds"><</span>VL53L1X.h<span class="pl-pds">></span></span></td>
src/tof_vl53l1x.h:1615:12: warning: missing terminating ' character
1615 | <!-- '"` --><!-- </textarea></xmp> --></option></form><form class="js-jump-to-line-form Box-body d-flex" action="" accept-charset="UTF-8" method="get">
src/tof_vl53l1x.h:1615:12: error: missing terminating ' character
src/tof_vl53l1x.h:1681:9: error: extended character ’ is not valid in an identifier
1681 | You can’t perform that action at this time.
src/tof_vl53l1x.h:7:1: error: expected unqualified-id before '<' token
7 | <!DOCTYPE html>
src/tof_vl53l1x.h:277:25: error: 'up' does not name a type; did you mean 'u8'?
277 | Sign up
| u8
src/tof_vl53l1x.h:739:25: error: expected unqualified-id before '<' token
739 | <div>{{ message }}</div>
src/tof_vl53l1x.h:1094:97: error: expected unqualified-id before '<' token
1094 | <span class="flex-1 css-truncate css-truncate-overflow {{ isFilteringClass }}">{{ refName }}</span>
src/tof_vl53l1x.h:1134:97: error: expected unqualified-id before '<' token
1134 | <span class="flex-1 css-truncate css-truncate-overflow {{ isFilteringClass }}">{{ refName }}</span>
src/tof_vl53l1x.h:1225:61: error: expected unqualified-id before '<' token
1225 | <div class="Skeleton Skeleton--text col-5 ml-2"> </div>
src/tof_vl53l1x.h:1229:56: error: expected unqualified-id before '<' token
1229 | <div class="Skeleton Skeleton--text col-1"> </div>
src/tof_vl53l1x.h:1409:152: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1409:195: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1418:150: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1418:188: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1422:150: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1422:191: error: expected unqualified-id before '<' token
src/tof_vl53l1x.h:1431:90: error: expected unqualified-id before '<' token
1431 | <td id="LC6" class="blob-code blob-code-inner js-file-line">VL53L1X tof_sensor;</td>
src/tof_vl53l1x.h:1573:74: error: expected unqualified-id before '<' token
1573 | <td id="LC40" class="blob-code blob-code-inner js-file-line">};</td>
src/tof_vl53l1x.h:1646:16: error: expected unqualified-id before numeric constant
1646 | © 2022 GitHub, Inc.
*** [/data/oiltank-sensor/.pioenvs/oiltank-sensor/src/main.cpp.o] Error 1
========================== [FAILED] Took 6.31 seconds ==========================
I am not sure what is wrong here - any help appreciated!
Thank you!
Hellis81
(Hellis81)
March 31, 2022, 3:53pm
6
This looks like an error due too an ESP-Home update.
I have no clue what to do. But this is the main reason why I never update an ESP-Home node unless I really have to
Scoff
(Scott)
April 5, 2022, 11:29am
7
Seeing exactly the same problem here trying to compile to upload a new config to my D1 Mini Pro board. It happens as soon as I add the vl53l1x.h into the ESP yaml file that I am trying to flash to my board. Is it a problem with ESPHome no longer accepting the syntax used in the custom component perhaps?
#include "esphome.h"
#include <Wire.h>
#include <VL53L1X.h>
VL53L1X tof_sensor;
class MyCustomSensor : public PollingComponent, public Sensor {
public:
// constructor
MyCustomSensor() : PollingComponent(5000) {} // polling every 5s
void setup() override {
// This will be called by App.setup()
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
tof_sensor.setTimeout(500);
tof_sensor.setAddress(0x29);
if (!tof_sensor.init()) {
ESP_LOGE("VL53L1X custom sensor", "Failed to detect and initialize sensor!");
while (1);
tof_sensor.setDistanceMode(VL53L1X::Short);
tof_sensor.setMeasurementTimingBudget(500000);
tof_sensor.startContinuous(50);
void update() override {
uint16_t mm = tof_sensor.read();
if (!tof_sensor.timeoutOccurred()) {
publish_state(mm);
} else {
ESP_LOGE("VL53L1X custom sensor", "Timeout during read().");
The log from trying to compile a very simple ESPHome config:
INFO Reading configuration /config/esphome/oiltank.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing oiltank (board: d1_mini_pro; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 16MB Flash
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Library Manager: Installing VL53L1x
Library Manager: Warning! More than one package has been found by VL53L1x requirements:
pololu/VL53L1X @ 1.3.1
mbed-1576028839/VL53L1X @ 0.0.0+sha.a71614c1b15b
mbed-jvfausto/VL53L1X @ 0.0.0+sha.621552ff1de9
mbed-st-expansion-sw-team/VL53L1X @ 0.0.0+sha.f16727052990
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (shown above) to avoid name conflicts
Unpacking [------------------------------------] 0%
Unpacking [##---------------------------------- ] 7%
Unpacking [#####------------------------------- ] 14%
Unpacking [#######----------------------------- ] 21%
Unpacking [##########-------------------------- ] 28%
Unpacking [############------------------------ ] 35%
Unpacking [###############--------------------- ] 42%
Unpacking [##################------------------ ] 50%
Unpacking [####################---------------- ] 57%
Unpacking [#######################------------- ] 64%
Unpacking [#########################----------- ] 71%
Unpacking [############################-------- ] 78%
Unpacking [##############################------ ] 85%
Unpacking [#################################—] 92%
Unpacking [####################################] 100%
Library Manager: VL53L1X @ 1.3.1 has been installed!
Dependency Graph
|-- 1.2.3
|-- 1.0
|-- 1.3.1
|-- 2.1.0
| |-- 1.2.3
| |-- 1.0
| |-- 1.0
|-- 1.1.1
|-- 1.0
|-- 1.2
|-- 6.18.5
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/api_connection.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/api_server.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/list_entities.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/proto.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/api/user_services.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/esp8266/core.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/esp8266/gpio.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/esp8266/preferences.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/json/json_util.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/logger/logger.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/md5/md5.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/mdns/mdns_esp_idf.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/network/util.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/socket/socket.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/web_server/list_entities.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/web_server/web_server.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/application.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/color.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/component.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/component_iterator.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/controller.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/entity_base.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/helpers.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/log.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/scheduler.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/esphome/core/util.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/src/main.cpp.o
Generating LD script /data/oiltank/.pioenvs/oiltank/ld/local.eagle.app.v6.common.ld
Compiling /data/oiltank/.pioenvs/oiltank/lib975/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling /data/oiltank/.pioenvs/oiltank/lib975/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
In file included from src/main.cpp:26:
src/tof_vl53l1x.h:8:63: error: expected class-name before ‘{’ token
8 | class MyCustomSensor : public PollingComponent, public Sensor {
src/tof_vl53l1x.h: In member function ‘virtual void MyCustomSensor::update()’:
src/tof_vl53l1x.h:35:7: error: ‘publish_state’ was not declared in this scope
35 | publish_state(mm);
*** [/data/oiltank/.pioenvs/oiltank/src/main.cpp.o] Error 1
========================= [FAILED] Took 90.55 seconds =========================
I was hoping that the vl53l1x sensor would have been supported natively in ESPHome by now rather than having to use the custom component, but perhaps soon it will.
Scoff
(Scott)
April 21, 2022, 6:10am
8
Hi Gareth, I’ve noticed that my code has started compiling correctly again, even though I haven’t updated ESPHone. I have updated Supervisor and Core to the latest versions however, so something withing these releases must has resolved the compile problem.
