I have he VLC add on to play sound through the 3.5 jack. I play a sound (mp3) and I can hear it fine once, but the second time I press play it only plays a small fraction of the beginning of the sound. I’ve tried different sound files and it does the same with any of them. I have to play a new file to be able to play a previous one again.
I have just installed vlc-telnet and also found that the audio coming out through the 3.5mm audio jack on the computer is often very broken up and does not play correctly. It seems to get worse if I adjust the volume of the play back whilst its happening.
Playing via another method such as the web browser works fine.
I want to be able to play audio via the local 3.5mm audio jack.
