Since two days the logs are full ERRORs
Even when I disable the VM FRITZ!Box Call Monitor Integration completely.
Haven’t changed anything to relevant HA config or inside fritzOS.
Does anyone else have the same issues?
Logs: (since Reset)
Logger: homeassistant.components.fritzbox_callmonitor.sensor
Source: components/fritzbox_callmonitor/sensor.py:237
Integration: AVM FRITZ!Box Call Monitor (documentation, issues)
First occurred: 7:26:18 (105 occurrences)
Last logged: 7:43:39
Connection has abruptly ended
@conradh
No, I just kept this Integration disabled since I don‘t use it anyway.
FritzOS has been updated a couple dass ago. You may give it a try.
Sorry for not providing a satisfying answer.
Had the same the day before yesterday. I just uninstalled the component, made a restart and added it back again. Worked for me.
But I don’t trust this, so I’ll keep an eye on it. Unfortunately the error messages don’t come up directly with the error, it takes a few days (for me). The phone sensor is not working and after three or four days the error messages start…
Nonetheless this is something you can sit out, as the functionality from this component (the phone sensor) will be implemented with the “normal” Fritz component. The technical part is already there, so it just needs to be implemented in the component. I’d say try with uninstall/re-install, if this doesn’t work, wait for a new version of the Fritz component.
