I am working on moving my Home Assistant from VirtualBox to VMware. However I have been able to successfully install and setup a VM with the .vmdk and I get a valid IP on the correct subnet when using Bridged. I can also see the CLI without any issues as it should normally display.
The next part when I try to access my Web UI in the browser, the page cannot be displayed.
I have no idea why I cannot do this simple task, Once super weird thing! I used the same .vmdk with VirtualBox and I was able to access the Web UI just fine.
So it must be something with the VMware settings I am assuming. I can ping the IP address and it comes back valid with ICMPs.
I’m currently at a lost and looking for any direction to try.
Thank you.
Well i did not actually use that .vmdk but I went to HA site and downloaded the .vdi when I was able to choose from .vmdk / .vdi.
I am using the IP address, it is in the same subnet as all my other VMs and as my host, etc.
I know the IP is valid and not being used.
On the CLI the IP matches the router IP.
What do you mean by port assignments?
I checked the network automatic and manually assigning the correct interface under bridged. When I manually assigned it I was able to ping the machine from other VMs. I use the same network interface on other VMs and I am able to SSH to multiple VMs together. So I know the bridged network interface is working. Just on my HAOS I am not able to access the GUI.
So I finally figured it out,
It ended up being:
Side Channel Mitigations enabled
Once I disabled this I was able to access the GUI in a VMware HAOS VM.
