Hello Everybody,
I have an issue with Voice Assistant activation.
The problem basically is that it is often activated without pronunce the wake word and this is too often
Is there anythging that I can change in the configuration to avoid or or at least mitigate it?
Depends on exactly how you are running it. There are various ways and various things you can do, so let us now what you are running, and we wonβt have to guess.
No the addons you are using, what config you have in those addons, and a bit more info than mic and speaker connected to hassio, it could be anything as there are so many ways to run ha. If you want help.you need to add all the info. All.the hardware you are using, any config files, logs etc
