Is there a way for a visual indication that the voice assistant is listening. I see the echo does it and has some code, to check the status, but how do I do it in home assistant automation or script?
Using openwakeword or porcupine1, Piper, Assist microphone and Whisper running on remote server.
All works well, I get the awake sound from the speaker but want to trigger an LED as well.
Would also love to use the voice output with a LED that can change the brightness (if you get what I’m trying to day).
I am not using the m5stack. I am using a USB microphone directly to the motherboard of home assistant server.
I have an Arduino mega connected, so the mega will have the LED.
