Voice Assistant Long-term Memory
Imagine asking Home Assistant:
“Where’s my car parked?”
“What’s my Wi-Fi password?”
“Remind me where I put the spare keys.”
With Memory Tool, your Voice Assist can now remember and recall information long-term - just like a personal assistant that never forgets.
Two editions are available depending on your needs:
Local Only - Private, offline, lightning fast.
LLM Integrated - Natural, conversational, powered by GPT/Gemini.
My GitHub repository for all dependency files
Edition 1: Local Only
This version runs entirely inside Home Assistant, no LLM or internet connection required.
Features (Local Only)
  • Works offline - fast, private, and secure.
  • SQLite with FTS5 full-text search for quick lookups.
  • Supports set, get, search, and forget, plus TTL, tags, and scopes.
  • Handles duplicates by updating existing memories or creating new ones.
Installation (Local Only)
  • Install and configure the Pyscript integration through HACS.
  • Copy scripts/memory.py and scripts/common_utilities.py into the config/pyscript folder.
  • Import the memory_tool_local.yaml blueprint and create an automation from it.
  • Dependency files are included in the repository.
  • Restart Home Assistant - the tool will automatically create its SQLite database on first run.
Edition 2: LLM Integrated
This version connects with an LLM (e.g., GPT, Gemini, …) to manage memory during conversations automatically.
Features (LLM Integrated)
  • Interact naturally and conversationally, in any language you choose.
  • The LLM decides when to run set, get, search, or forget.
  • Can refine queries, update existing keys, or create new entries dynamically.
  • Uses the same SQLite + FTS5 backend, with extra flexibility thanks to LLM reasoning.
Installation (LLM Integrated)
  • Copy scripts/memory.py into the config/pyscript folder.
  • Import the memory_tool_full_llm.yaml blueprint and create a script (do not change the default script name).
  • Requires specific usage rules and system policies - see home_assistant_voice_instructions.md for details.
Example: Local vs LLM
Scenario: Saving and retrieving your parking spot
Local Only Edition (exact commands, keyword-based)
You: “Remember office parking spot is in basement 3 near the elevator entrance”
You: “Find office parking spot”
Assist: “in basement 3 near the elevator entrance”
You: “Find parking spot”
Assist: “I found a few candidates: 1. office_parking_spot: in basement… Say a number to open it, or say cancel?”
You: “One”
LLM Integrated Edition (natural language, context-aware)
You: “Hey, I left my car somewhere… where did I park again?”
Assist: “You told me your car is parked in basement 3 near the elevator entrance”
You: “Actually I moved it to basement 2, column 6”
Assist: “Got it, I’ve updated your parking spot to basement 2, column 6”
Local = precise, offline, reliable.
LLM = flexible, conversational, smarter.
Real-World Use Cases
  • Store and recall Wi-Fi passwords, parking locations, reminders, phone numbers, or any details you want.
  • Save temporary or long-term notes, with TTL configurable up to 10 years - or forever.
Which Edition Should You Choose?
  • Local Only - Best for privacy, speed, and offline reliability.
  • LLM Integrated - Best for natural conversations and smarter handling of memory.
Both editions will continue to be developed in parallel. I’d love feedback from anyone who tries them - especially ideas for new use cases or improvements!
After I set it up according to your method (local version), I still cannot read the memory when talking to the language assistant.
I don’t know where to find more logs. Can you elaborate on your tutorial?
Me:Remember my parking spot is B2 R1
Assist:Done
Me:what is my parking spot
Assist:I don’t have any information about your parking spot in the available smart home devices.
In addition, “Dependency files are included in the repository.”this sentence means that the two files scripts/memory.py and scripts/common_utilities.py are already placed in your repository, right?
Thanks~
I just updated the post to include my GitHub repository (I hit the new user link limit!). Just follow the installation steps there to get access to the feature. Please use it and send me your feedback so I can improve it. Thank you!
Hey everyone,
Quick heads-up: I just rolled out a minor update to fix bugs in the duplicate keyword score calculation and the incorrect delete confirmation logic.
If you’ve been using this feature, please drop a comment below and let me know if it’s working for you!
On the flip side, if you spot any new bugs or have an idea for a cool new enhancement, please share it! Your feedback is super helpful to helping me decide what to upgrade next.
Thanks for all your support!
Can you consider making a detailed video or graphic tutorial? I really don’t know how to use it after installation.Thanks~
Hello! I assume you’re using the Local Version, correct?
If so, you need to open the automation that was created from the blueprint. Inside the Trigger settings, you will see the commands used to store and recall information. You are able to customize these commands there.
The Local Version strictly requires you to speak using the exact syntax for it to work. If you’d like to use more natural language, you will need to switch to the LLM version.
I’m setting this up right now,
Already translated the google generative ai initial instructions .
Commands in the blueprint needs to be translated too, yes?
Hello!
You’re using the LLM version, right? Regarding the instructions for the LLM, you can either copy the content exactly as is or customize it. You should keep the instructions in English and there’s no need to translate them.
I just realized I forgot one crucial step in the current LLM version installation: you need to expose the script to the Assistant after the script has been saved.
Hello everyone,
I’ve just updated the Local Version to make the content more TTS-friendly. Also, the README page now has an English version, which should make it easier for everyone to understand and also check out some other pretty interesting blueprints.
This is great, pls think to make an video with install and use, not all of us know HA well :), ty so much for effort to make it
You can look at the following example of the Local Version to get an idea of how it works. The LLM Version is slightly different in that the conversational interaction is more natural and less constrained by strict syntax or grammar. Regarding creating video tutorials, I will consider it, but English is not my first language, so producing an easily understandable English video for everyone is not simple for me. I hope you understand. The installation process is actually easy and not complicated at all.
super hard to set it up i still did not manage to make it work, i just install all made like in instructions , still i dont know how to use it , i tell the assistant to remember my birthday and he is not sometimes it access the script sometimes not, who know what he is doing it :)) anyway , great work man , sry that i cant make it work, was nice to see it working.
PS. i did try to get the answer from the AI after i close the ollama and open again so i can see if is permanent memory.
i come back now after some time learning to work with this and i can say that is super easy integration and it works, confirmed i saw the inside db and using the full one but with my local AI.
Big THANKS for this.
Great to see this feature is working well for you! Please don’t hesitate to report any bugs or suggest improvements, I’m ready to make it even better.
Hey can the LLM integrated version be used with local ollama models as well?
I haven’t tested this yet, but I believe it should work. Could you please run a test and leave a comment detailing the results? If the local AI can successfully handle other commands via natural language, it should be compatible with this LLM version as well.
Hey, thank you for this great feature, I just set it up and it works quite well. Really cool. But I have one problem with it… It seems to be working only for the actual session, so when I close the app or the browser and I ask later, the information seems to be not consistent.
Even the voice is forgetting the information after some time. The information is there when I ask immediately for it.
Additional Inhave the effect, that I can give different information to different devices and I get the different information back. It’s like they are using different memories, but it’s all over the same script.
BR Bernd
PS: Is there a possibility to check the database/memory? Whre can I find it?
Hello, this tool exposes several actions to Home Assistant. You can call them directly under Developer Tools - Actions, similar to other actions. All actions will be prefixed with pyscript.memory_. For example, you can use pyscript.memory_search to verify if the data has actually been stored, or pyscript.memory_forget to manually delete stored data.
my testing yesterday was really promising but unfortunately it does not really work in the end. I’m still testing and may give some feedback when i had more time.
Thank you so far.
BR Bernd
