Voice assistant not working
So I configured faster-whisper, open wake word, and piper using the assistant microphone and a USB microphone to try to make it work. It says that it’s assisting me when I say Alexa, but piper always says unknown. Whisper and open wake word just have the date and time or something. I tried doing it in silence when clicking the mic mute thing to make sure it only heard what I want. What is this year of voice thing? I thought it would function. Like at least to some extent.
Edit
So I restarted everything and it worked once. Lke it issued a single command, to turn on goodnight. Then proceeded to fail to respond to any other commands. It seems to respond to the first command and nothing else.
Here’s assist microphones log
File “/usr/local/lib/python3.11/dist-packages/wyoming/server.py”, line 37, in run
event = await async_read_event(self.reader)
File “/usr/local/lib/python3.11/dist-packages/wyoming/event.py”, line 79, in async_read_event
json_line = await reader.readline()
File “/usr/lib/python3.11/asyncio/streams.py”, line 545, in readline
line = await self.readuntil(sep)
File “/usr/lib/python3.11/asyncio/streams.py”, line 637, in readuntil
await self._wait_for_data(‘readuntil’)
File “/usr/lib/python3.11/asyncio/streams.py”, line 522, in _wait_for_data
await self._waiter
File “/usr/lib/python3.11/asyncio/selector_events.py”, line 995, in _read_ready__data_received
data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
INFO:root:Connected to server
INFO:root:Streaming audio
Playing raw data ‘stdin’ : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
WARNING:root:Did not receive ping response within timeout
INFO:root:Disconnected from server
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name=‘wyoming event handler’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=ConnectionResetError(104, ‘Connection reset by peer’)>
await self._waiter
await self._waiter
Open wake word has no logs
Piper has no logs
File “/usr/lib/python3.9/asyncio/streams.py”, line 190, in _drain_helper
raise ConnectionResetError(‘Connection lost’)
ConnectionResetError: Connection lost
INFO:faster_whisper:Processing audio with duration 00:15.000
INFO:wyoming_faster_whisper.handler: .
INFO:wyoming_faster_whisper.handler: I’m not going to let you go for a second I don’t know if you’re going to run or not If you’re going to run or not, I will be there We all have a bunch of things like which you write on the slide So you don’t know what to do I don’t know
future: <Task finished name=‘wyoming event handler’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:31> exception=ConnectionResetError(‘Connection lost’)>
File “/usr/local/lib/python3.9/dist-packages/wyoming/server.py”, line 41, in run
if not (await self.handle_event(event)):
File “/usr/local/lib/python3.9/dist-packages/wyoming_faster_whisper/handler.py”, line 95, in handle_event
await self.write_event(self.wyoming_info_event)
File “/usr/local/lib/python3.9/dist-packages/wyoming/server.py”, line 29, in write_event
await async_write_event(event, self.writer)
File “/usr/local/lib/python3.9/dist-packages/wyoming/event.py”, line 131, in async_write_event
await writer.drain()
File “/usr/lib/python3.9/asyncio/streams.py”, line 387, in drain
await self._protocol._drain_helper()
INFO:wyoming_faster_whisper.handler: I’m a little bit more tired than what I was trying to tell you, it’s not that it’s a place that you’ve been with me. But I can’t say, it’s not that I’m a little bit more tired than what I was trying to tell you.
INFO:wyoming_faster_whisper.handler: I don’t have a solution. Okay. I got a lot of things to do with everything. I don’t like these cells. I’ll tell them to wait for the radio to get you. Just make a little bit of a push to go. I’ll tell them to do it.
INFO:wyoming_faster_whisper.handler: The other one is a good night.
INFO:wyoming_faster_whisper.handler: I’ll let you know. I’ll let you know. Relax up. Third. I’ll let you know.
INFO:wyoming_faster_whisper.handler: It’s a little bit of a difference between a square, a square, a square, a square, a square, a square, a square and a square. The difference is that you can’t decide what you’re going to do to decide. The difference between a square and a square, a square, a square, a square, a square.
INFO:wyoming_faster_whisper.handler: . . . . .
INFO:wyoming_faster_whisper.handler: . . . . . . . .
INFO:wyoming_faster_whisper.handler: chart.
INFO:wyoming_faster_whisper.handler: on the power.
INFO:wyoming_faster_whisper.handler: on Good Night.
INFO:wyoming_faster_whisper.handler: Turn on the good night.
INFO:wyoming_faster_whisper.handler: turn on good night
INFO:wyoming_faster_whisper.handler: Turn on good night
Whisper literally has the words needed to function and perform the task at the end. It didn’t work. The lights never turned off. What is going on?
If you type it into assist, rather than speak it, does that work ?
And what reply is assist sending, if any ?
It works fine when using the feature on my overview or even using the microphone on my phone. Perfectly fine. It’s the audio part of it with the USB microphone. Also I don’t bother with a speaker for it I don’t care what it says I just need it to perform actions. Do a thing.
So it looks like Piper isn’t working?
It’s giving me an error.
So I changed the external URL and that fixed the issue with piper. It’s still not working though.
Whenever I say the trigger word the speakers make a beeping noise to acknowledge it, then a little while later they make another beeping noise. And it does not execute any commands. So to be clear the voice commands for the home assistant do not work. I can see in logs the words for the commands of which I am trying to use. So something in the Wyoming protocol logs the words that I’m saying but somehow they don’t get executed. The exact same words were perfectly fine when typing it out on my phone using the assistant.
did you manage to solve this issue i have the exact problem
all seems to work , but the wake word dont work at all
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=ConnectionResetError(104, 'Connection reset by peer')>
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 37, in run
  File "/usr/local/lib/python3.11/dist-packages/wyoming/event.py", line 79, in async_read_event
  File "/usr/lib/python3.11/asyncio/streams.py", line 545, in readline
  File "/usr/lib/python3.11/asyncio/streams.py", line 637, in readuntil
    await self._wait_for_data('readuntil')
  File "/usr/lib/python3.11/asyncio/streams.py", line 522, in _wait_for_data
    await self._waiter
  File "/usr/lib/python3.11/asyncio/selector_events.py", line 995, in _read_ready__data_received
Honestly the whole thing is such a fucking pain in the ass it’s entirely pointless it crashed my home assistant every time I tried to use it. It has so much work needed for the echo atom to work right. I couldn’t even update it properly it took countless times and kept failing. It’s not user friendly at all and buggy as hell. I have multiple z wave switches to do it now. I just can’t deal with that nonsense. I’ll wait until they go another “year of voice” or whatever and actually get this thing together in a functional way. The guide on home assistants website isnt even really that explicit on how to setup the echo. I had to use a guide on another website. Your better off just quitting while your ahead with this specific aspect of it. Plus if the air conditioner is on your so screwed their is no way it’s gonna pick a single word up, it misunderstood me constantly. And if I used the more robust model to recognize words it worked a little better sure, and took literally like over two minutes to work sometimes. I would go oh it crashed again then like two minutes later it would finally finish processing what I said and then respond. usually incorrectly.
