Voice Assistant PE - No voice output
I am having trouble getting any vocal output on the device.
When selecting “SET UP VOICE ASSISTANT” on the device menus, It tests the wake-word twice, I select an area and then when selecting the hardware I selected do it yourself. I have a mini PC dedicated for HA and I intended to run and LLM locally even if it is slow. The next screen has 3 drop-down menus. The bottom one is to select a voice, no matter which voice I select if I press the “Try” button next to it an error shows up at the bottom that says “Failed to perform the action assistant_satellite/announce. Media source not loaded” When I try to test the Voice PE It wakes and beeps to the wake word but after a simple question it blinks for a bit and flashes red. I have not been able to setup the LLM yet but I cannot get it to output anything. I have Whisper and Piper installed and running and have checked for updates on everything. What is causing this issue, how can I resolve it?
Resolved! TLDR: I did not have “media_source:” included in my config yaml files.
Full Explanation: The “BROWSE MEDIA” button was not present for me. I remember using this feature when originally testing my MiniPC setup. Since then I tried to make a full manual config to better understand the system and process of customizing HA. “media_source:” is included in the default config yaml and I missed it in my custom config.
