New device arrived today. Excited to get it hooked up but I’m having issues.
I’ve read the other threads similar to my issue but I’m not getting past this point
The voice assistant is unable to connect to Home Assistant
I have Home Assistant installed on linux box inside a docker container with bridge networking.
- the container is exposing port 8123
- Outbound is allowed
- inbound from 192.168.0.0/24 to port 8123 is allowed
I have the device on my network and it’s been given an IP by the router
I have added the VA device to ESPHome using that IP
When I try to go throught the ESPHome > Setup Voice Assistant wizard I ge tthe “The voice assistant is unable to connect to Home Assistant” error with the sad robot.
I have edited my “Settings > System > Network” to have the external web address box empty and the local set for “Automatic” to false and the Local address to be the static LAN IP of the linux box.
I’ve run out of ideas for what to do. Any suggestions? HA can reach the device (I’m able to change the LEDs etc) The device doesn’t appear to be able to know how to reach HA. HA is routable and reachable from other wifi devices on the same network.
