I would like to use Assist with my voice. However, 3rd party STT services (OpenAI, Google, MS) are not an option for me due to privacy.
I have already deployed a web STT service that accepts HTTP POST request with audio (WAV format, PCM codec) and returns text, which works well. I have also created a custom HA component that should send the audio to my web STT serice.
How do I list my custom component in that dropdown?
Or do you know any custom integration/addon that would allow me to configure my own URL address for the STT service?
Thanks!
Wrap it in wyoming protocol it’s much easier, the client is already in the system, so no additional integration is required.
Use any project from GitHub as an example.
What do I wrap in wyoming protocol - my web STT service? It is a JavaScript app running in a serverless CloudFlare worker, so not sure whether wrapping it like that is possible. Or easy.
And I believe everything else is in place for STT to work end-to-end, I just need to be able to select my component in the dropdown. That would be the easiest approach, but it’s not clear to me how to make a custom component show up in that dropdown. Any help on that would be much appreciated!
If your stt entity is registered in the system, it will be displayed. Look at the logs, debug the code.
What integration did you base your solution on?
Look at this project
Hi, I’ve built something similar and wrote a blog post about it, so I’m hoping you will find it helpful.
The gist of it is:
I have a Wyoming server written in Python that declares itself as an STT service. By connecting the Wyoming integration to this server, you will see this custom server listed in the dropdown.
If you have an existing web STT service, you could have the Wyoming server forward the audio to your service, similar to how my implementation of the Wyoming server forwards the audio to the OpenAI API SDK.
Unfortunately, my suggestion would mean running two servers: the Python Wyoming server and your JavaScript STT app.
