Voice Assistant using Vulkan backends and Kokoro TTS
I’ve assembled a full new chain to make a Voice Assistant for my new AMD Ryzen AI 9 HX 370 mini-PC. I wanted to use Vulkan to use my iGPU for acceleration of inference. In addition, I wanted to try out Kokoro TTS engine instead of Piper since it wins most the be constests.
Here are the components:
  • Llama-Server runs the LLM to generate responses and call tools. Ollama doesn’t support Vulkan, and doesn’t recognize GTT memory which is a strength of the APUs (instead of reserving part of your RAM as VRAM, you let your iGPU use as much RAM as it needs, dynamically, no need to reboot in the BIOS to adjust VRAM allocation).
  • Ollama-proxy exposes Llama-Server using the same API as Ollama. This is required because Home Assistant doesn’t let users change the base URL of their OpenAPI or OpenRouter integrations. Only the Ollama integration lets you do it. Ollama-proxy implements streaming, tools, and reasoning (however, I couldn’t get Home Assistant to give back past reasoning traces yet). It doesn’t support multi-modal (images) yet.
  • Wyoming-Whisper.cpp implements ASR (Automatic Speech Recognition) using Whisper.cpp. Home Assistant offers Wyoming-Faster-Whisper already, but it doesn’t run on Vulkan.
  • Wyoming-Kokoro-Torch It implements the TTS (Text-to-Speech) using Kokoro. It’s fast enough to run on a CPU, but you can build your own Docker image to add CUDA or ROCm runtime. As of the time of writing, contrary to kokoro-wyoming, Wyoming-Kokoro-Torch supports streaming mode, so that your voice assistant will start speaking before the LLM is fully done generating a response.
So, yup, I forked everything except llama-server :sweat_smile: Some code need a refactor, but it should all work correctly.
Llama-Server and Wyoming-Whisper.cpp never run at the same time. The ASR always runs first obvisouly, and the whole decoded text will then be fed to the LLM. However, Llama-Server and Wyoming-Kokoro-Torch run concurrently, since the TTS will generate audio while the LLM is generating text.
Why Vulkan?
  1. It’s vendor-agnostic, most (all?) GPUs drivers will implement it.
  2. The library is generally compact, my container for Radeon is 500 MiB intead of 10+ GiB if I used ROCm.
  3. Llama.cpp’s implementation on top of Vulkan got as fast, if not faster, than other implementation in spring 2025. See Phoronix’s article.
  4. In the case of Radeon, “it just works” using any recent Linux distribution. Some software using ROCm insisted on downloading the DKMS drivers from AMD, which in turn broke the Secure Boot of my system.
  5. Ollama doesn’t even work nicely on AMD APUs, the community currently needs to use a fork of Ollama if they whish to use GTT (using “normal” RAM instead of the dedicated VRAM).
The LLM
GPT OSS 20B is used, but any other LLM supported by Llama.cpp with support for tools can be used. This model is using only 3.6B parameters for each token produced, while using just 12GiB of storage.
Optimizations
The template of GPT OSS 20B has been hacked to optimize the caching of the prompts. That model starts with an “identity” prompt to tell it what it is, followed by a list of built-in tools, then the system prompt, and finally the tools offered by the user. Because Home Assistant puts the current time at the end of the system prompt, the whole description of tools would have to be reevaluated on each new chat. The hacked template is moving all tools before the system prompt. GPT OSS 20B is still making use of those tools just fine, but it removes about 3 seconds of processing time on my AMD Ryzen AI 9 HX 370 on each new chat.
We use the Q8_0 quantized version of GPT OSS 20B. On the AMD Ryzen AI 9 HX 370, layers quantized in Q8 run faster than F16 or Q4. This speeds up prompt processing by about 10%.
The AMDVLK (user) driver is used since it’s still a bit faster than RADV for prompt processing. However, since AMD is now working on RADV instead of AMDVLK, the situation could change.
Contrary to the ASR and TTS of Home Assistant, I don’t use temporary files to save audio. It’s all in-memory.
Speed
Measured in a Proxmox VM with iGPU passthrough:
System Model Prompt Processing (pp512) Token Generation (tg128)
AMD Ryzen AI 9 HX 370 GPT OSS 20B (Q8_0) 550 25
You may also this Llama.cpp Backend Performance Comparison page, to see the “optimal” librairies to run each LLM on an AMD Ryzen AI MAX+ 395. Again, this is a moving target. The best solution could change over time as software is being optimized.
Containers
All applications needed to turn Home Assistant in to a digital assistant have been containerized. The Dockerfiles to build the images below are included in this repository. This makes it easier to manage the dependencies of each application, and deploy them. If you don’t want to install containers, both wyoming applications can be installed from PyPi, ollama-proxy can be installed via go install, while llama-server can be obtained from downloaded their releases page.
Here is a list of all images, and their size.
REPOSITORY TAG IMAGE ID SIZE (on disk)
debackerl/llama-server-vulkan b6432-amdvlk-2025.q2.1 e327b4e19a86 443MB
debackerl/ollama-proxy be8a17e 6b4581e24a1e 28.6MB
debackerl/wyoming-whisper.cpp v2.6.1-amdvlk-2025.q2.1 c7e392c9cea2 541MB
debackerl/wyoming-kokoro-torch v3.1.0-cpu 55d974f6baf2 1.53GB
Example to create the containers:
docker create --name llama-server --device /dev/dri -p 0.0.0.0:8086:8080 -v /home/XXX/models:/models debackerl/llama-server-vulkan:b6432-amdvlk-2025.q2.1 /app/llama-server -fa 1 --jinja --alias llama-server -c 65536 -np 2 -b 1024 -ub 1024 -m /models/language/gpt-oss-20b-Q8_0.gguf --chat-template-file /models/language/gpt-oss-20b-optimized.jinja --chat-template-kwargs "{\"reasoning_effort\":\"low\",\"model_identity\":\"You are a helpful digital assistant, based on the GPT-OSS 20B model by OpenAI.\"}"
docker create --name ollama-proxy -p 0.0.0.0:11434:11434 debackerl/ollama-proxy:be8a17e /bin/ollama-proxy http://assistant.lan.etive.com:8086/v1/ open
docker create --name wyoming-whisper-cpp --device /dev/dri -p 0.0.0.0:10210:10000 -v /home/XXX/models:/models debackerl/wyoming-whisper.cpp:v2.6.1-amdvlk-2025.q2.1 /usr/local/bin/wyoming-whisper-cpp --uri tcp://0.0.0.0:10000 --model large-v3-turbo-q8_0 --data-dir /models --language en --beam-size 2
docker create --name wyoming-kokoro-torch -p 0.0.0.0:10500:10210 -v /home/XXX/models:/models debackerl/wyoming-kokoro-torch:v3.1.0-cpu /usr/local/bin/wyoming-kokoro-torch --debug --streaming --uri tcp://0.0.0.0:10210 --voice af_sky --data-dir /models
Tip: if you love killer robots coming from the future speaking with an Austrian accent, you may love the am_onyx voice in kokoro.
Models
Most of those containers will require models to be downloaded in the /home/XXX/models directory.
LLM for llama-server
ASR for wyoming-whisper.cpp
Auto-downloaded
TTS for wyoming-kokoro-torch
You need to download the following two files:
Voices are automatically downloaded, but you can also download them from hexgrad/Kokoro-82M at main
Future
Parakeet TDT 0.6B v3 seems like a much faster, and more accurate ASR model than Whisper. It should be adopted when a Vulkan implementation is ready. There are two ONNX implementations but it would require MIGraphX to run on AMD.
Fish Speech 1.5 has good ratings too, offers more languages, and can sound even more natural, but uses more resources.
I hope that somebody finds this useful. I setup a GitHub repository to keep updates to my Dockerfiles (GitHub - debackerl/home-assistant-vulkan-voice-assistant: Scripts to run a voice assistant using Vulkan API · GitHub).
Laurent
Big thanks for this. I’m super excited to see kokoro working in streaming mode, and it works.
Quick question on the versions of the images, do you plan to push a 3.1.0 of the kokoro one as I currently just see 3.0.0 on dockerhub.
If you plan on keeping these up to date, use of a latest tag would be greatly appreciated. I’ll happy point to them from my unraid server and let it auto update them on a cron.
Thanks again.
I’m happy if it’s useful to someone else :wink:
Yes, I will push updates to DockerHub, forgot 3.1. The difference was a new option to adjust volume because Kokoro voices are a bit quiet. I will do it soon.
I will probably keep images up-to-date every other month. I use this for my own setup.
Laurent
Can you please create latest tags for the images? That would make keeping up to date a little easier.
@debackerl Could you rebase GitHub - debackerl/wyoming-whisper.cpp: Wyoming protocol server for whisper.cpp speech to text system ?
The upstream GitHub - rhasspy/wyoming-faster-whisper: Wyoming protocol server for faster whisper speech to text system has made some interesting improvements, including adding support for Parakeet.
Ollama 0.12.11 release on November 12 supports Vulkan!
Perhaps this will simply your setup, removing the need to fork and use llama-server and ollama-proxy?
hey. did you find good TTS for Vulkan?
I currently use Piper-tts, quality is ok, but not great …
I been using the kokoro-torch from this thread for months and basically any text I send to it gets generated in less than a second.
I was trying qwen-tts yesterday and got it working on vulkan and while the result audio is amazing the time for each phrase was about 3-4 seconds which is not ideal
is there any support for other language than english?
i tried the --voice ff_siwis but i still get answer in frenglish instead of french.
Do you still need your Kokoro Torch, or is the official one working now with streaming?
