I need help to configure hass…
I set up a smart house for my elderly grandfather. The task is to transmit the voice by hass to rpi to communicate with him. Is it possible to make everything in the web interface when I click on the microphone rpi reproduced everything I say?
I have raspberry pi2 model B with Home Assistant onboard. There is the “mic” icon in web interface.
I want to make it so that when you click on “mic” in web and say anything raspberry pi reproduced it in the speakers connected to it
i am not sure if that is easily configurable. the mic icon on the homepage only accepts basic on/off commands or custom commands via the conversation component: (https://home-assistant.io/components/conversation/)
It might be possible to configure a command that calls the Google Text-to-Speech component (https://home-assistant.io/components/tts.google/). Which can in turn speak pre configured message to one of your audio devices.
