Voice pipeline not "attaching" to voice assistant
I am having trouble getting my ESP voice assistant to work.
It seems to be set up correctly as I get the static on the speaker after boot, but if I check my logs it only gets as far as :[C][api:173]: Using noise encryption: YES"
Looking at others logs like this one Logs I don’t get the “state changed from idle”
I’ve set up and configured Whisper, Openwakeword and Piper.
Is the issue possibly in my code?
esphome:
  friendly_name: Voice assistant 1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: *****
ota:
  - platform: esphome
    password: *****
wifi:
  ssid: I ❤️ my WiFi
  password: ******
  manual_ip:
    static_ip: 192.168.0.136
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  ap:
    ssid: "Voice-Assistant-1"
    password: "1PFW9o4nvxbf"
captive_portal:
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26   #WS / LRC
    i2s_bclk_pin: GPIO25    #SCK /BCLK
microphone:
  - platform: i2s_audio
    adc_type: external
    pdm: false
    channel: left
    bits_per_sample: 32bit
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO33    #SD
speaker:
    dac_type: external
    i2s_dout_pin: GPIO27   #DIN
    channel: mono
voice_assistant:
  microphone: mic_i2s
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 4.0
  use_wake_word: true
  speaker: my_speaker
  on_error:
   - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - switch.turn_off: use_wake_word
          - switch.turn_on: use_wake_word
  on_client_connected:
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
Study this configuration and adapt it for yourself. It is the most relevant for standard esp32 boards
