Voice Recorder Card: Record your voice on the dashboard
I’ve used this path and made the folders in the root (media is in the same map als WWW). But no files are appearing. What log do I need to check exacly?
If there are no messages or error logs, it usually means the recording file has been saved successfully. Please carefully check if there is a file in your folder.
Alternatively, you can share screenshot of your configuration.
Also, you don’t need to create a folder manually. The integration will automatically create a folder based on the path you’ve set. If your path starts with /media, it will create the folder under the media directory. If the path doesn’t start with /media, it will create the folder under /homeassistant.
If your configured path is www, it will be saved in /homeassistant/www. If the path is www/your_dir, it will be saved in /homeassistant/www/your_dir.
Thank you for your effort, I did everything… I got no errors, I got file saved notification, but cannot find the file in the directory, may be I miss something or what to do please
Actually I can see the recorded files from inside Home assistant (file editor), but when browsing from file explorer I can not find the recorded files.
everything is working fine. I can now send an announcement to my home :heart_eyes:
Thank you :kissing_heart:
Is it possible to hide the drop down menu, so will have only the MIC icon shown ?
2
Hi
nice job done for this add!
Reverting to have only the mic icone should be wonderful (possibility to hide the drop-down menu!)
Had some trouble figuring this out so putting reference for others.
Configured Voice Recorder output file path to /media/voice_recordings
Then for media_content_id I had to put /media/local/voice_recordings/{{ trigger.event.data.filename }} .
I tried first with just {{ trigger.event.data.path }} but that would not work. It would be nice if the integration could output the “local” path as well.
alias: play voice notification
description: ""
triggers:
  - trigger: event
    event_type: voice_recorder_saved
conditions: []
actions:
  - action: media_player.play_media
      entity_id: media_player.announcement_speakers
      media_content_id: "/media/local/voice_recordings/{{ trigger.event.data.filename }}"
      media_content_type: music
mode: single
Hello… the voice recorder card record well my voice, but I cannot get it played on my Alexa echo…
Does it still work for you?
