Voicemeeter virtual audio mixer
is anyone using voicemeeter and homeassistant?
is anyone trying to integrate them?
voicemeeter is an absurdly powerful virtual audio mixer, with built-in ‘macro-button’ system and VBAN - a comprehensive multi-stream audio over ip solution
these solutions are all donationware. they are being used fairly widely in professional and semi-professional environments.
macrobuttons can be defined in ui or xml, and perform a very long list of actions within and outside of the voicemeeter program - launch programs, send keypresses, do so conditionally on state of the mixer, eg i make a midi controller light flash if input on a given channel is over 6db, or switch output between different audio systems, including (via VBAN) other computers on the network, and my phone. it can send audio outside of local network too.
voicemeeter also has an api which allows for wide-ranging control of the setup.
i’m thinking there may be ways to bridge vm to homeassistant, which would be very very powerful for creating and controlling multi-zone audio systems, with multiple inputs, including audio-over-ip, taking audio from different applications and processing independently (eg reverb on that channel, eq on this one, 5.1 on this channel, stereo on that one, etc) all eminently controllable through automations and manual inputs from midi controllers, homeassistant android, or literally any other input…
i’m a novice coder, but i’m hacking away at a few personal projects and might be able to contribute here, but i’d need a little help determining approaches and strategies, and if i can’t use python i’m probably out…
would love to see that integration too
I use Voicemeeter Potato and am in the same boat. I’m only really looking to be able to control output devices for each input and volume, and any other features would be a bonus. I’m also a pretty novice python coder, and I’d love to try and help in some way. I’ve used the BarRaider Voicemeeter plugin on my Stream Deck for a few years and it works great for controlling nearly every feature in Voicemeeter, Voicemeeter Banana and Voicemeeter Potato by using the VoicemeeterRemoteAPI. It seems there are already a few python libraries that tie into the Voicemeeter API, so I might try experimenting with this. I don’t know too much about making HA intergrations, but I might try and make this tie into MQTT as that is probably easier for me to tinker with.
so i found hass.agent, set up mosquitto MQTT, and now i can control my computer (including media and wake-on-lan) from HA, and likewise control HA from my computer.
so far my voicemeeter ‘integration’ consists of some midi buttons mapped to VM macro-buttons which fire global hotkeys configured in hass.agent. i’m sure hotkeys isn’t the best way, but it’s a start
I may be able to investigate this soon but before I do must first learn lots more about home assistant integrations.
Did anything ever come of this?
+1
It sure would be nice to control Voice Meeter Potato the way I control everything else… through Home Assistant.
It’s in the works! Havent got anything to share yet, might be awhile before I try publishing to hacs and such, but I’m hoping to atleast have a repo to show in the coming week.
output
Edit: Didn’t notice you at first in the thread @onyx-and-iris, I’m using your voicemeeter api go wrapper :smiley:
Thank you for your efforts, and I’m really looking forward to this component!
Thank you so much for your hard work! I have successfully deployed your plugin to my Home Assistant, and I now have the ability to directly control my VoiceMeeter Banana software mixer from Home Assistant — this is an incredibly exciting capability!
Based on this, I’ve already created my first “magical” automation: every morning when no one is home, it automatically turns on the home theater PC, adjusts the volume to an appropriate level, and then plays media of a cockatiel whistling. I’ve been trying to use automation to train my cockatiel to learn how to whistle every day, but the default volume is set for watching movies and is a bit too loud — before using your plugin, I couldn’t find a suitable solution for this.
As a next step, I may consider implementing audio ducking: when a phone call is detected in the living room, the current movie volume is automatically reduced, and when the call ends, the volume is restored. What an amazing feature that would be!
Thank you once again!
Thanks for the kind words! To everyone here, it should be compatible with HACS now. So just add the github url to your custom repos in HACS and you’ll get updates and stuff. The companion app now tries reconnecting for awhile on startup and has a manual reconnect button aswell so its a bit easier to handle.
If you guys wanna discuss specific features or code and stuff, we should probably do so on github :slight_smile:
I just made this because I wanted to control my VM setup with HA built for Potato but I think it should work with others... GitHub - thegeekoftheworld/Voicemeeter-MQTT-Bridge: Voicemeeter MQTT Bridge · GitHub
Hey, yes I noticed. This is really cool, I’m glad someone with lots of knowledge about HA got involved and created the integration. You’ve done a great job!
U are so awesome, wow finally the voicemeeter integration, thought about listing it on hacs?
really I appreciate this so much, cuz i was wanting this for ages
and I am thinking about centralizing my voicemeeter to a ubuntu running parallel to my home assistant on an external device to my main computer, so idk how hard it is to make a linux compatible version for this, but in case you have too much time i’d love to see that :))
keep up ur awesomeness<3
