Voip - Add 3cx support
3cx is a popular voip system. I use it in my home.
I am able to call it when i set the SIP Trunk to the home assistant address but it look like it’s missing something with the codec.
Im able to receive audio (from home assistant), the assistant can get the key tone when i press a key, it say it did not understand but it dont seem to be able to receive the audio from my mic …
If implementing a SIP trunk, we can implement extension to different assistant or command/automatisation …
As far as I know but I might be wrong 3CX is very closed system and doesn’t have any API to control/interact with it so no way to develop an integration for it !
it use a standard protocol. So if the plugin can use this protocol, it will be compatible…
Might double check that 3CX is set up to support the Opus codec, as that is the only one HA supports at this time (there’s another Feature Request for other Codecs)
Some IP-phones also send server specific codes as standard and might need an extra key pressed to send DTMF codes for keypresses.
This works for me:
This allowed HA to get my audio and convert it to text.
Wait for the release of 3CX v20, there will be API support at least for the admin page.
and we won’t have the 3CX management console anymore…
I know this hasn’t seem much action recently but i would love this integration personally.
