Volume command not working since last app upgrade (after updating to new schema)
Looks like since the recent Companion app update to version 2022.8.0 the commands to change the volume doesn’t work anymore
I have updated the notification schema according to the new docs (from title to data: command:)
A sample current config:
service: notify.mobile_app_pixel_5
  message: command_volume_level
    command: 0
    media_stream: music_stream
But the app simply shows a notification with this message
Tried to put the command under quotation marks and without, no change.
I’ve also restarted both the app and HA server.
Any thoughts?
here is a working service call to change the ringer volume for my android device:
      - service: notify.mobile_app_my_mobile_app
          message: "command_volume_level"
            media_stream: "ring_stream"
            command: "{{volume_level}}"
I send the volume level (i.e. 100) from an automation.
It looks the same as yours so I’m not sure why yours isn’t working.
Once I’ve set the command value under quotation marks, it started working (that’s another breaking change, it worked without it):
    command: "0"
interesting.
I have the same issue. Doesn’t work even with the quotes.
same for me, worked fine but suddenly stoped working
Im dumb af
It Works fine :man_facepalming:
I just discovered that 0 (without quotes) does not work (as stated by others before) but that -1 (without quotes) works, i.e., reduces volume to zero/off.
In Node-RED, “0” (with quotes) works fine.
