Volume Control
My Home Assistant
UPDATED 16-4-2022 // volume levels only adjusted in given time
This blueprint is for volume control your media_player devices.
Simply give in your media_players, the time that the volume must go up and down,
And your desired volume levels.
And enjoy your automatic volume control.
20-12-2020 16:50 : as stated by @KTibow the time has to be in increments of 30 minutes. eg: 07:30:00 or 08:00:00
Github Gist: https://gist.github.com/r3mcos3/9da622593b43d3ed166b9bed3dd5c85b
blueprint:
  domain: automation
  name: Volume Control 2.0
  input:
    media:
      description: Media players to use
      default: []
      selector:
          entity:
            domain: media_player
    time_up:
      description: Time that the volume goes up
      default: 00:00:00
      selector:
        time:
    time_down:
      description: Time that the volume goes down
      default: 00:00:00
      selector:
        time:
    volume_up:
      name: Volume Up Level
      description: The volume goes to this level when the up time is reached
      default: 0.6
      selector:
        number:
          min: 0.1
          max: 1.0
          step: 0.1
          mode: slider
    volume_down:
      name: Volume Down Level
      description: The volume goes to this level when the down time is reached
      default: 0.2
      selector:
        number:
          min: 0.1
          max: 1.0
          step: 0.1
          mode: slider
mode: single
- platform: time
  at: !input 'time_up'
- platform: time
  at: !input 'time_down'
- choose:
  - conditions:
    - condition: time
      before: !input 'time_down'
      after: !input 'time_up'
    sequence:
    - service: media_player.volume_set
      target: !input 'media'
        volume_level: !input 'volume_up'
  - conditions:
    - condition: time
      before: !input 'time_up'
      after: !input 'time_down'
    sequence:
        volume_level: !input 'volume_down'
Let me know if you have issues.
Typo correction:
  description: Time based volume control of your media devices
Also you should probably note that the time can only be a multiple of 30 minutes.
Updated :hammer:
Thnx for your suggestions :+1:
