One more thing, how to have the current playlist? There are REST API command : https://volumio.github.io/docs/API/REST_API.html
How to use them?
hey,
good to hear that it works!
if you want to play a certain playlist, you have to create a scipt and a shell command.
both is described in my post, which is directly above your first post!
if you need further help, just tell me!
I just discovered Volumio and Iām excited to get into it.
Itās probably over kill for this purpose, but do any of you use it to play MP3 files as actions for Automations? Like Dog bark sounds when motion detected and no one is homeā¦
No, but when you add the component you can already use it as text-to-speach target.
Hello, in which section of the config in HOME ASSISTANT go to write the code:
ā¦volumio_playlist1:
alias: Fat Freddys Drop
sequence:
- service: shell_command.volumio_fatfreddys
in configuration.yaml ?
Hi, you can tell me how to call a Volumio radio station from HA? Thankās!
Hi nek1970,
yes for sure. I made a playlist with only the radiostation and play it with a shell command. itās the same command i use for other playlists.
here is the command for my favourite (austrian) radiostation FM4
shell command:
volumio_fm4: 'curl 192.168.0.185/api/v1/commands/\?cmd\=playplaylist\&name\=FM4'
I created a playlist called Classic FM and I saved a radio inside it. In configuration.yaml
I also added the command for the random function to my mp3 playlists. That does not work either.
My yaml config looks like this:
media_player:
platform: volumio
host: 192.168.178.64
port: 3000shell command:
volumio_classic_fm: ācurl 192.168.178.64/api/v1/commands/?cmd=playplaylist&name=Classic_FMā
curl 192.168.178.64/api/v1/commands/?cmd=random
ok, first of all, make sure, that the ssh command is working. you have to use exactly the same command as i posted and you have to prepare your piās so that a ssh connection without pw is working. follow this guide: http://linuxproblem.org/art_9.html
further, the shell command is an extra entry and not under the entry media player.
the shell_command can be triggered by a script.
it should look like this:
media_player:
- platform: volumio
host: 192.168.0.185
port: 3000
shell_command:
volumio_fatfreddys: 'curl 192.168.0.185/api/v1/commands/\?cmd\=playplaylist\&name\=Fat%20Freddys%20Drop'
EDIT: Ah sorry, i mixed it up. You donāt have to follow the ssh-guide. Iām sorry, i donāt know why it isnāt working for you
Hi, Iām trying to create some playlists in VOlumio. At the moment, however, it still does not work.
My config:
config.yaml
script.yaml
can you Help me?
Thankās!
Oh yes, now i see whats wrong.
Delete %20drop at the end of the command.
Because thatās part of my playlist name, which is āFat Freddys Dropā in volumio.
no work.
now my config is:
media_player:
platform: volumio
port: 3000shell_command:
curl 192.168.178.64/api/v1/commands/?cmd=playplaylist&name=prova1
script:
volumio_playlist:
alias: prova1
sequence:
- service: shell_command.volumio_prova1
have you any idea?
can you post the code in the proper way? with the function āpreformatted textā? otherwise, post again a screenshot. i donāt know why it isnāt working. in volumio, the playlist is also called āprova1ā?
Hi, now WORKS. I see the playlist.
2 Questions:
In your opinion is it possible to insert an input_select to group the scripts?
You could better explain how to insert the Random function. I wrote this but it doesnāt work.
THANKāS!!!
I never used the input_select function and i donāt know how to use itā¦ unfortunately, iām not a programmer
For shuffle, i use this shell command:
volumio_shuffle: 'curl 192.168.0.185/api/v1/commands/?cmd=random'
Edit: I guess you use the right command, but forgot the ā ā around the command
thankās for your support!
Hello, I was trying to configure input numbers for Volumioās playlist. Did you succeed? Could you tell me how?
FYI, playing predefined playlists works even easier.
They appear as mediaplayer āsourceā and can be started from the UI out of the box:
Alternatively, there is a service that can be called to switch sources: media_player.select_source
I added some picture entity cards to lovelace with the stationās logos that start the playlist on press:
- cards:
- image: /local/media_fm4.jpg
type: picture
tap_action:
action: call-service
service: media_player.select_source
service_data:
entity_id: media_player.volumio
source: FM4
Iām just curiousā¦ is it possible to set a playlist or song to repeat from UI?
I would like to put a media player of some inexpensive kind in each of my kids rooms and, at bedtime, have it play a local playlist of relaxation music.
Ideally, i would just like something like a Pi that I can hook to some cheap desktop speakers and remotely control the audio playback and volume. Icing on the cake would be audio sync but they donāt have to be since they are in different rooms and wonāt be so loud that it would be noticeable.
Yes, everything you want to realize should be possible.
Setting volumio to repeat is possible with this shell command:
volumio_repeat: 'curl 192.168.0.185/api/v1/commands/?cmd=repeat'
Playing a certain playlist is described above.
Syncing them isnāt supported by volumio (i guess), but using a script, whichs fires two shell commands playing the same playlist should be a good workaround.
