does anyone know if it is possible to setup the MPD integration (for TTS with Volumio) in Home Assistant such that Volumio pauses its previously played source, plays the TTS file and then resumes the previous source? Does anyone have an idea how to set it up?
I have a similar question, so if you made any progress l would love to hear.
When I manually added the Volumio integration it created a lovelace card that seemingly works well, except for the TTS part which just throws an error: JSONDecodeError: Expecting value: line 1 column 1 (char 0)
I’ve managed to set up a config entry for Volumio-MPD:
This sort of works for sending a TTS command via the Lovelace card but only if nothing is playing. If something is playing it seems to to try to, pause -> send TTS -> resume but it goes wrong. The timing is possibly out so the TTS audio doesn’t play and it also then skips to a different track too.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/volumio/media_player.py:256
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:06:43 (1 occurrences)
Last logged: 12:06:43
[2765719104] Expecting value: line 1 column 1 (char 0)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 135, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1445, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 181, in async_say_handle
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 593, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 630, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/volumio/media_player.py", line 256, in async_play_media
await self._volumio.replace_and_play(json.loads(media_id))
File "/usr/local/lib/python3.8/json/__init__.py", line 357, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.8/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.8/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
I also noticed it tries to pause and then starts to play again without playing the TTS.
I tried to make a sequence with a script (Pause->playt tts->delay->Play) and it actually works great.
You have to tweek the delay to the length of the TTS.
You also can check with a condition if volumio is playing or not and determine if its neccesary to excecute the Play/Pause service
