I am trying to use Vosk, but there seems to be “only” a hass.io addon.
I tried building the Dockerfile from here, but since there is no CMD it doesn’t run, I guess it is missing some hass.io magic.
Should I run rhasspy instead?
Thanks!
Thanks!
What’s a “Vosk”? A link would help.
There is a link to the hass.io addon in the post It is a speech recognition toolkit.
Here is a link to the underlying vosk-project.
My issue is that I can’t get it to work because it’s a hass.io addon, but I am not using hass.io.
The link you posted to the Vosk addon does not work.
there is a link to it here. if It helps anyone.
Thanks, Arh!
Weird, the link works on my end…
I couldn’t find another solution so I created my own container:
Thank you! It works fine for me on my Intel N100.
In my case I use Spanish, do you know how I can configure it to download the large version for Spanish? By default, using “PRELOAD_LANGUAGE=es” downloads the small version, regards.
I can’t test this as I am out for work for the next few days, but you should be able to just dump any model in the dir of your language.
So in your case inside your model dir there should be a dir called es and inside that folder you should put the model you want to use. Then restart the container.
Let me know if that works
Yes, that’s what I did and it worked, now it understands me perfectly and goes quite fast.
Thank you very much for your contribution
My pleasure
Would you mind sharing what hardware you are running the large model on? Just in case other people consider using the large dataset with a comparable hardware.
Sure:
Firebat T8 Pro Plus minipc
Processor: Intel n100
Ram: 8GB
Storage: SSD 256GB
Nowadays there are better ones, what I liked about this one was its low consumption (less than 5W) very similar to Raspberry but with an architecture that does not give so many headaches and better performance.
hi, i want to use vosk in italian due to the fact that whisper is very poor in my native language.
Can you describe me the steps you did to enhance it?
I installed it with this settings but definitely there’s something wrong:
thanks!
See this reply
I checked my /share/ folder and I don’t have any “vosk” folder.
Should i create it and put the extracted files from vosk-model-it-0.22.zip?
What does your docker-compose.yaml look like?
I realized there were a few things that could be improved (and a few things that were wrong, so I updated the repo). The readme now contains a section on how to choose your model.
Let me know what I can improve:
When starting the container it’ll tell you which model it loaded.
@jonatanpradasn
I checked the advice I gave you and it was probably wrong, I am surprised it works for you. Giving you a ping in case you want to double check.
I’ll test tonight if I have time (and if I’m able to do it maybe I’ll create a unraid template to spread the word )
I keep you posted
I tried to use your local compose in my unraid environment without success
Fantastic, works much better than faster-whisper, no problems in the installation process, except that it doesn’t use the template you downloaded and put in “dirs/models/it” but uses the “small” template of the language template put in docker-compose.
i’d need some input because can’t connect vosk to HA-wyoming:
Quick look at log shows that vosk container is running…
CORRECT_SENTENCES = 0.0
PRELOAD_LANGUAGE = de
DEBUG_LOGGING = TRUE
LIMIT_SENTENCES = TRUE
ALLOW_UNKNOWN = False
flags = --debug --limit-sentences
DEBUG:root:Namespace(uri='tcp://0.0.0.0:10300', data_dir=['/share/vosk/models'], download_dir='/data', language='de', preload_language=['de'], model_for_language={}, casing_for_language={}, model_index=0, sentences_dir='/share/vosk/sentences', database_dir='/share/vosk/sentences', correct_sentences=0.0, limit_sentences=True, allow_unknown=False, debug=True, log_format='%(levelname)s:%(name)s:%(message)s')
DEBUG:root:Preloading model for de
DEBUG:wyoming_vosk.download:Downloading: https://huggingface.co/rhasspy/vosk-models/resolve/main/de/vosk-model-small-de-0.15.zip
LOG (VoskAPI:ReadDataFiles():model.cc:213) Decoding params beam=10 max-active=3000 lattice-beam=2
LOG (VoskAPI:ReadDataFiles():model.cc:216) Silence phones 1:2:3:4:5:6:7:8:9:10
LOG (VoskAPI:RemoveOrphanNodes():nnet-nnet.cc:948) Removed 0 orphan nodes.
LOG (VoskAPI:RemoveOrphanComponents():nnet-nnet.cc:847) Removing 0 orphan components.
LOG (VoskAPI:ReadDataFiles():model.cc:248) Loading i-vector extractor from /data/vosk-model-small-de-0.15/ivector/final.ie
LOG (VoskAPI:ComputeDerivedVars():ivector-extractor.cc:183) Computing derived variables for iVector extractor
LOG (VoskAPI:ComputeDerivedVars():ivector-extractor.cc:204) Done.
LOG (VoskAPI:ReadDataFiles():model.cc:282) Loading HCL and G from /data/vosk-model-small-de-0.15/graph/HCLr.fst /data/vosk-model-small-de-0.15/graph/Gr.fst
LOG (VoskAPI:ReadDataFiles():model.cc:308) Loading winfo /data/vosk-model-small-de-0.15/graph/phones/word_boundary.int
INFO:root:Ready
flags = --debug --limit-sentences --model-for-language vosk-model-small-de-0.15 /share/vosk/models/vosk-model-small-de-0.15
DEBUG:root:Namespace(uri='tcp://0.0.0.0:10300', data_dir=['/share/vosk/models'], download_dir='/data', language='de', preload_language=['de'], model_for_language={'vosk-model-small-de-0.15': '/share/vosk/models/vosk-model-small-de-0.15'}, casing_for_language={}, model_index=0, sentences_dir='/share/vosk/sentences', database_dir='/share/vosk/sentences', correct_sentences=0.0, limit_sentences=True, allow_unknown=False, debug=True, log_format='%(levelname)s:%(name)s:%(message)s')
DEBUG:root:Found vosk-model-small-de-0.15 at /share/vosk/models/vosk-model-small-de-0.15
LOG (VoskAPI:ReadDataFiles():model.cc:248) Loading i-vector extractor from /share/vosk/models/vosk-model-small-de-0.15/ivector/final.ie
LOG (VoskAPI:ReadDataFiles():model.cc:282) Loading HCL and G from /share/vosk/models/vosk-model-small-de-0.15/graph/HCLr.fst /share/vosk/models/vosk-model-small-de-0.15/graph/Gr.fst
LOG (VoskAPI:ReadDataFiles():model.cc:308) Loading winfo /share/vosk/models/vosk-model-small-de-0.15/graph/phones/word_boundary.int
INFO:root:Ready
Any ideas? It’s propably any config error by me?
Thx
