In order to connect to HA from outside your network from the phone, you need to either use duckdns and open ports in your router
Or connect via VPN.
To connect via VPN you need to enable VPN settings on your whole phone(at least in iOS), or maybe (not sure about this last one) enable VPN inside a browser app, though browser would let us just see dashboards but won’t upload the phone sensors (battery, location…)
I would love to have the VPN enabled just for HA app on the phone.
Adding the possibility to VPN straight from the app would be great.
What’s wrong with a VPN for your whole phone? That way other apps are safer too.
Besides that, Iike the ha developers to spend their time on cool features like they do now, not working on a VPN client. But you are welcome to develop it.
If you use the Tailscale addon / VPN, only the Tailscale traffic will go through the VPN, not all your traffic (by default at least), if that’s what you mean.
If you actually mean to enable a VPN per app, I doubt this is possible.
On iOS LTP2 VPNs tend to self disconnect after some time. Also Speeds drop massively.
I wouldn’t mind for myself to connect and disconnect the VPN, but thinking about my 70yo parents :S
+1 for Auto start vpn when starting ha client on android.
I do not want to open inbound ports neither want to run vpn all the time. Just when using ha (or some other apps)
So would be nice if ha auto starts a pre configured vpn.
For anyone, who is still looking for solution, I managed to emulate that feature using an iOS Shortcuts - it’s simply enable/disable VPN every time I open or close HA app.
I want this feature as well.
Running VPN on my phone, like tailscale, kills battery life. Not worth it for couple of times per day I open HA app. Also, enabling and disabling tailscale every time is a no-go.
There is absolutely no reason to expose my HA publicly and VPN solutions I’ve found so far are not good.
