VSC debug issue
I hope there is some simple issue but I cannot find reason for days.
I set VSC with HA container according to documentation. I am able to run HA using predefined Tasks - Terminal - Run Tasks - ‘Run Home Assistant Core’. Then Im able to configure HA via localhost:8123. All seems ok. But When I attempt to run a debug I got a bunch of errors in ‘selectors.py’ module of Python.
Can you please advice what is wrong with my setup?
You might want to install all the requirements in your devcontainer to avoid this.
I did install those from Tasks, i took a while but I believe it has installed packages to the right place. Below the log after debug run. the first error occures with
File "/workspaces/core/homeassistant/util/async_.py", line 118, in check_loop
    raise RuntimeError(
RuntimeError: Detected blocking call inside the event loop. This is causing stability issues. Please report issue
This is a place in async_.py when it scans components
        for path in ("custom_components/", "homeassistant/components/"):
            try:
                index = frame.filename.index(path)
                found_frame = frame
Can there be a problem with permitions to some folders?
DEBUG LOG:
root ➜ /workspaces/core (dev) $  cd /workspaces/core ; /usr/bin/env /usr/local/bin/python /root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/launcher 40665 -- -m homeassistant --debug -c config
  File "_pydevd_bundle/pydevd_cython.pyx", line 1078, in _pydevd_bundle.pydevd_cython.PyDBFrame.trace_dispatch
  File "_pydevd_bundle/pydevd_cython.pyx", line 297, in _pydevd_bundle.pydevd_cython.PyDBFrame.do_wait_suspend
  File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/_vendored/pydevd/pydevd.py", line 1976, in do_wait_suspend
    keep_suspended = self._do_wait_suspend(thread, frame, event, arg, suspend_type, from_this_thread, frames_tracker)
  File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/_vendored/pydevd/pydevd.py", line 2011, in _do_wait_suspend
    time.sleep(0.01)
  File "/workspaces/core/homeassistant/util/async_.py", line 155, in protected_loop_func
    check_loop(strict=strict)
    raise RuntimeError(
    time.sleep(0.01)
  File "/workspaces/core/homeassistant/util/async_.py", line 156, in protected_loop_func
    return func(*args, **kwargs)
SystemExit
    time.sleep(0.01)
SystemExit
    time.sleep(0.01)
SystemExit
2022-01-20 11:26:11 WARNING (Thread-8) [homeassistant.util.executor] Thread[SyncWorker_0] is still running at shutdown: File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydev_bundle/pydev_monkey.py", line 1054, in __call__
    ret = self.original_func(*self.args, **self.kwargs)
  File "/usr/local/lib/python3.9/threading.py", line 930, in _bootstrap
    self._bootstrap_inner()
  File "/usr/local/lib/python3.9/threading.py", line 973, in _bootstrap_inner
    self.run()
  File "/usr/local/lib/python3.9/threading.py", line 910, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 82, in _worker
    if work_item is not None:
    time.sleep(0.01)
2022-01-20 11:26:12 WARNING (Thread-8) [homeassistant.util.executor] Thread[SyncWorker_0] is still running at shutdown: File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydev_bundle/pydev_monkey.py", line 1054, in __call__
    self.run()
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 83, in _worker
    work_item.run()
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 53, in run
    def run(self):
    time.sleep(0.01)
2022-01-20 11:26:13 ERROR (MainThread) [root] Uncaught exception
  File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/__main__.py", line 45, in <module>
    cli.main()
  File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/../debugpy/server/cli.py", line 444, in main
    run()
  File "/root/.vscode-server/extensions/ms-python.python-2021.12.1559732655/pythonFiles/lib/python/debugpy/../debugpy/server/cli.py", line 331, in run_module
    run_module_as_main(target_as_str, alter_argv=True)
  File "/workspaces/core/homeassistant/__main__.py", line 319, in <module>
    sys.exit(main())
  File "/workspaces/core/homeassistant/__main__.py", line 306, in main
    exit_code = runner.run(runtime_conf)
  File "/workspaces/core/homeassistant/runner.py", line 119, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
    return future.result()
  File "/workspaces/core/homeassistant/runner.py", line 101, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/workspaces/core/homeassistant/bootstrap.py", line 131, in async_setup_hass
    await async_from_config_dict(config_dict, hass) is not None
  File "/workspaces/core/homeassistant/bootstrap.py", line 215, in async_from_config_dict
    await asyncio.gather(
  File "/workspaces/core/homeassistant/setup.py", line 78, in async_setup_component
    return await task
  File "/workspaces/core/homeassistant/setup.py", line 156, in _async_setup_component
    integration = await loader.async_get_integration(hass, domain)
  File "/workspaces/core/homeassistant/loader.py", line 588, in async_get_integration
    integration = await _async_get_integration(hass, domain)
  File "/workspaces/core/homeassistant/loader.py", line 606, in _async_get_integration
    if integration := (await async_get_custom_components(hass)).get(domain):
  File "/workspaces/core/homeassistant/loader.py", line 151, in async_get_custom_components
    evt = hass.data[DATA_CUSTOM_COMPONENTS] = asyncio.Event()
  File "_pydevd_bundle/pydevd_cython.pyx", line 1363, in _pydevd_bundle.pydevd_cython.SafeCallWrapper.__call__
  File "_pydevd_bundle/pydevd_cython.pyx", line 662, in _pydevd_bundle.pydevd_cython.PyDBFrame.trace_dispatch
  File "_pydevd_bundle/pydevd_cython.pyx", line 1087, in _pydevd_bundle.pydevd_cython.PyDBFrame.trace_dispatch
    time.sleep(0.01)
    raise RuntimeError(
Removed Container
Removed VSC
Removed Docker
Refreshed forked /core on github
rebooted
Install all those again
Installed requirements_all.txt
user is in docker group
… absolutely same error …
Amazing… I created a new test user to my ubuntu, added it to docker group, ran installation and I am able to run the debugger without any errors!
How do I revert the installation when I press OPEN button on the step 2 from the official page ?
