I know this is not a VSCode forum but I thought I would post here as most likely to be people with similar setups that maybe have a similar issue and know of a fix.
So, the basic problem I have is that I get continual freezes of the VSCode instance while using HA dev container under Debian 12 ina VBox environment. I see it hammering the disk (so much so, that the whole Debian environment freezes waiting for access to the disk).
Sometimes I get a VSCode not responding message and if I manage to click close (and it closes when there is some availability to the disk queue), everything frees up again. In most cases, I have to power off the machine through VBox menu (or machine crashes itself). It does not seem to do this with any other VSCode instance I have running.
I only really do HA development with VSCode, so am usually running a few VSCode instances with one being the HA Dev Container.
A bit more about my setup.
Running VBox 7.0.20 with extensions installed in the Debian 12 install
AMD Ryzen 9 3900X 12 core system with 24 virtual cores, 12 allocated to the Debian VM
Total 16GB RAM with 8GB allocated to VM
Windows 11 on host
I used to have an Ubuntu VM to do HA Dev but moved to Debian as had the same issue in that environment and I just thought it needed rebuilding so started with a fresh Debian install. However, the issue has followed.
Has anyone else experienced this and found a solution as it’s driving me nuts!
