VSCode not incompatible anymore with HA
I had some issues with my HA and I had to reinstall a new HA on a SD card for Raspberry Pi. I restored from the latest back up and everything works fine but the VSCode which used to work fine before on the same Raspberry Pi machine.
It gives the following error:
“This add-on is not compatible with the processor of your device or the operating system you have installed on your device.”
“Add-on a0d7b954_vscode not supported on this platform, supported architectures: aarch64, amd64”
Here are details of my HA:
System Information
version core-2023.4.6
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.10
os_name Linux
os_version 6.1.21-v7l
arch armv7l
timezone Australia/Adelaide
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.32.1
Stage running
Available Repositories 1271
Downloaded Repositories 9
Home Assistant Supervisor
host_os Home Assistant OS 10.1
update_channel stable
supervisor_version supervisor-2023.04.1
agent_version 1.5.1
docker_version 23.0.3
disk_total 57.8 GB
disk_used 4.1 GB
healthy true
supported true
board rpi4
supervisor_api ok
version_api ok
installed_addons Home Assistant Google Drive Backup (0.110.4), SSH & Web Terminal (13.1.0), Duck DNS (1.15.0), eufy-security-ws (1.3.5), RTSPtoWeb - WebRTC (1.4.0)
It is not supported.
You need to reflash with the 64 bit image of Home Assistant OS 10.1
