I launched HA 3 weeks ago (HAOS on MiniPC via Proxmox, Sonoff Zigbee stick, Zigbee2mqtt) and have been playing Zigbee wack-a-mole since. Most of my devices are Iris 3320-L contact sensors and Iris 3326-L motion sensors. They all are 5+ years old which they spent paired with SmartThings hub and worked flawlessly. The only maintenance needed was replacing batteries every 2-3 years.
Very different story on HA. Once a day or so a random sensor would become unavailable. In most cases taking battery out for 10 seconds and putting it back fixes it. When it doesn’t, nothing helps except firing up old SmartThings hub, pairing the sensor with it, and unpairing. That somehow cleanses the sensor and it connects to HA again.
Sometimes the issue is failure to update open/closed status. It would say it’s closed despite it being open or vice versa. While reporting temperature and battery status without an issue. Taking the battery out and putting it back in fixes it. Until the next sensor.
There is no rhyme or reason which devices will stop working. The proximity to the zigbee stick or LQI seem to have no impact. I also have several GE zigbee lights and they do the same. But turning the power off/on always fixes them.
Looking for dead sensors and reinserting the battery to bring them back to live became a nightly chore. It’s starting to get old. How can I get the Zigbee network reliability in par with what I had with SmartThings?
I’m on channel 11 now. I don’t know what channel SmartThings was on, to tell the truth I had no idea Zigbee had channels at all back then.
I did not have any router devices with SmartThings, besides lights, which weren’t always on so don’t know if they count. The SmartThings hub and now a mini-PC with HAOS are right in the center of a rather small house and LQI is reasonable everywhere as is. But a few weeks ago I did add a Zigbee plug which now provides routing which brought LQIs even higher, but had no impact on this wack-a-mole.
The interference theory is interesting but wouldn’t these facts contradict it:
A device works 100% and then it stops completely; comes back to 100% after battery is reinserted. Wouldn’t interference make it sometimes work, sometimes not?
In cases where sensor stops reporting open/close but keeps reporting temperature and battery - would’t all messages go on the same channel? Why would reinserting the battery fix it?
By now probably 2/3 of devices had this happened once, and only one of them twice. Wouldn’t there be more of repeat offenders, probably ones with low LQI?
The ZBDongle-P you linked to is what I have. Check the firmware version. I’ve had recent purchases with old firmware. Compare and update if need with the latest release at Releases · Koenkk/Z-Stack-firmware (github.com).
Extension is definitely the lowest hanging fruit.
If on zigbee channel 11 then avoid Wifi Channel 1, move Wifi to channels 6 or 11.
There is hope, my zigbee is stable using the same dongle.
Looks like it’s old. I don’t see any button in HA to update it. Googling results in countless youtube videos and instructions of doing this outside on HA, presumably a different computer. Would you kindly point me to the best approach for this particular dongle?
Wifi is on Auto; analyzer shows 5ghz on 157 and 2.4ghz on 8.
I use the cc2538-bsl script, much easier than the Windows nonsense.
But…
Zigstar has an add-on to do it all in HA. Once setup it makes future updates prety much point and click:
Just tested below steps:
Take a z2m or ZHA adapter backup as appropriate, and an HA backup to be safe.
Stop Zigbee2mqtt addon/Disable ZHA as appropriate
Add repo to addon store
Refresh Page
Install ZigStar TI CC2652P FW Flasher addon
Edit addon configuration tab:
. select appropriate adapter
. enter “0” for network address (probably a bug - shouldn’t be necessary)
. enable “Network device/USB Device” toggle
. enable “Sonoff USB” toggle
. DISABLE “Enable Bootloader mode for Network Device” toggle
. save configuration
Start ZigStar TI CC2652P FW Flasher Addon
Monitor ZigStar TI CC2652P FW Flasher Log Tab for status (click “Refresh” every second or so). Time to complete should be around 10-20 seconds. Sample log below.
Restart Zigbee2mqtt or enable ZHA as appropriate.
Sample Successful Log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
Add-on: ZigStar TI CC2652P FW Flasher
ZigStar TI CC2652P firmware flasher add-on
Add-on version: 0.2.6
You are running the latest version of this add-on.
System: Home Assistant OS 10.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.9.3
Home Assistant Supervisor: 2023.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service cc2652-flasher: starting
[17:49:56] INFO: Starting CC2652P flasher with Sonoff /dev/ttyUSB1
Setting filename to /root/firmware.hex
sonoff
Opening port /dev/ttyUSB1, baud 500000
Reading data from /root/firmware.hex
Your firmware looks like an Intel Hex file
Connecting to target…
pg_rev = 3, protocols = f, wafer_id = 0xbb41
CC135x PG2.0 (7x7mm): 352KB Flash, 20KB SRAM, CCFG.BL_CONFIG at 0x00057FD8
Primary IEEE Address: 00:12:4B:00:26:B8:82:2F
Performing mass erase
Erasing all main bank flash sectors
Erase done
Writing 360448 bytes starting at address 0x00000000
Write 248 bytes at 0x00000000
Write 248 bytes at 0x000000F8
Write 248 bytes at 0x000001F0
Write 248 bytes at 0x000002E8
Write 248 bytes at 0x000003E0
Write 248 bytes at 0x000004D8
Write 248 bytes at 0x000005D0
Write 248 bytes at 0x000006C8
Write 248 bytes at 0x000007C0
Write 248 bytes at 0x000008B8
Write 248 bytes at 0x000009B0
Write 248 bytes at 0x00000AA8
Write 248 bytes at 0x00000BA0
Write 248 bytes at 0x00000C98
Write 248 bytes at 0x00000D90
Write 248 bytes at 0x00000E88
Write 248 bytes at 0x00000F80
Write 248 bytes at 0x00001078
Write 248 bytes at 0x00001170
Write 248 bytes at 0x00001268
Write 248 bytes at 0x00001360
Write 248 bytes at 0x00001458
Write 248 bytes at 0x00001550
Write 248 bytes at 0x00001648
Write 248 bytes at 0x00001740
Write 248 bytes at 0x00001838
Write 248 bytes at 0x00001930
Write 248 bytes at 0x00001A28
Write 248 bytes at 0x00001B20
Write 248 bytes at 0x00001C18
Write 248 bytes at 0x00001D10
Write 248 bytes at 0x00001E08
Write 248 bytes at 0x00001F00
Write 248 bytes at 0x00001FF8
Write 248 bytes at 0x000020F0
Write 248 bytes at 0x000021E8
Write 248 bytes at 0x000022E0
Write 248 bytes at 0x000023D8
Write 248 bytes at 0x000024D0
Write 248 bytes at 0x000025C8
Write 248 bytes at 0x000026C0
Write 248 bytes at 0x000027B8
Write 248 bytes at 0x000028B0
Write 248 bytes at 0x000029A8
Write 248 bytes at 0x00002AA0
Write 248 bytes at 0x00002B98
Write 248 bytes at 0x00002C90
Write 248 bytes at 0x00002D88
Write 248 bytes at 0x00002E80
Write 248 bytes at 0x00002F78
Write 248 bytes at 0x00003070
Write 248 bytes at 0x00003168
Write 248 bytes at 0x00003260
Write 248 bytes at 0x00003358
Write 248 bytes at 0x00003450
Write 248 bytes at 0x00003548
Write 248 bytes at 0x00003640
Write 248 bytes at 0x00003738
Write 248 bytes at 0x00003830
Write 248 bytes at 0x00003928
Write 248 bytes at 0x00003A20
Write 248 bytes at 0x00003B18
Write 248 bytes at 0x00003C10
Write 248 bytes at 0x00003D08
Write 248 bytes at 0x00003E00
Write 248 bytes at 0x00003EF8
Write 248 bytes at 0x00003FF0
Write 248 bytes at 0x000040E8
Write 248 bytes at 0x000041E0
Write 248 bytes at 0x000042D8
Write 248 bytes at 0x000043D0
Write 248 bytes at 0x000044C8
Write 248 bytes at 0x000045C0
Write 248 bytes at 0x000046B8
Write 248 bytes at 0x000047B0
Write 248 bytes at 0x000048A8
Write 248 bytes at 0x000049A0
Write 248 bytes at 0x00004A98
Write 248 bytes at 0x00004B90
Write 248 bytes at 0x00004C88
Write 248 bytes at 0x00004D80
Write 248 bytes at 0x00004E78
Write 248 bytes at 0x00004F70
Write 248 bytes at 0x00005068
Write 248 bytes at 0x00005160
Write 248 bytes at 0x00005258
Write 248 bytes at 0x00005350
Write 248 bytes at 0x00005448
Write 248 bytes at 0x00005540
Write 248 bytes at 0x00005638
Write 248 bytes at 0x00005730
Write 248 bytes at 0x00005828
Write 248 bytes at 0x00005920
Write 248 bytes at 0x00005A18
Write 248 bytes at 0x00005B10
Write 248 bytes at 0x00005C08
Write 248 bytes at 0x00005D00
Write 248 bytes at 0x00005DF8
Write 248 bytes at 0x00005EF0
Write 248 bytes at 0x00005FE8
Write 248 bytes at 0x000060E0
Write 248 bytes at 0x000061D8
Write 248 bytes at 0x000062D0
Write 248 bytes at 0x000063C8
Write 248 bytes at 0x000064C0
Write 248 bytes at 0x000065B8
Write 248 bytes at 0x000066B0
Write 248 bytes at 0x000067A8
Write 248 bytes at 0x000068A0
Write 248 bytes at 0x00006998
Write 248 bytes at 0x00006A90
Write 248 bytes at 0x00006B88
Write 248 bytes at 0x00006C80
Write 248 bytes at 0x00006D78
Write 248 bytes at 0x00006E70
Write 248 bytes at 0x00006F68
Write 248 bytes at 0x00007060
Write 248 bytes at 0x00007158
Write 248 bytes at 0x00007250
Write 248 bytes at 0x00007348
Write 248 bytes at 0x00007440
Write 248 bytes at 0x00007538
Write 248 bytes at 0x00007630
Write 248 bytes at 0x00007728
Write 248 bytes at 0x00007820
Write 248 bytes at 0x00007918
Write 248 bytes at 0x00007A10
Write 248 bytes at 0x00007B08
Write 248 bytes at 0x00007C00
Write 248 bytes at 0x00007CF8
Write 248 bytes at 0x00007DF0
Write 248 bytes at 0x00007EE8
Write 248 bytes at 0x00007FE0
Write 248 bytes at 0x000080D8
Write 248 bytes at 0x000081D0
Write 248 bytes at 0x000082C8
Write 248 bytes at 0x000083C0
Write 248 bytes at 0x000084B8
Write 248 bytes at 0x000085B0
Write 248 bytes at 0x000086A8
Write 248 bytes at 0x000087A0
Write 248 bytes at 0x00008898
Write 248 bytes at 0x00008990
Write 248 bytes at 0x00008A88
Write 248 bytes at 0x00008B80
Write 248 bytes at 0x00008C78
Write 248 bytes at 0x00008D70
Write 248 bytes at 0x00008E68
Write 248 bytes at 0x00008F60
Write 248 bytes at 0x00009058
Write 248 bytes at 0x00009150
Write 248 bytes at 0x00009248
Write 248 bytes at 0x00009340
Write 248 bytes at 0x00009438
Write 248 bytes at 0x00009530
Write 248 bytes at 0x00009628
Write 248 bytes at 0x00009720
Write 248 bytes at 0x00009818
Write 248 bytes at 0x00009910
Write 248 bytes at 0x00009A08
Write 248 bytes at 0x00009B00
Write 248 bytes at 0x00009BF8
Write 248 bytes at 0x00009CF0
Write 248 bytes at 0x00009DE8
Write 248 bytes at 0x00009EE0
Write 248 bytes at 0x00009FD8
Write 248 bytes at 0x0000A0D0
Write 248 bytes at 0x0000A1C8
Write 248 bytes at 0x0000A2C0
Write 248 bytes at 0x0000A3B8
Write 248 bytes at 0x0000A4B0
Write 248 bytes at 0x0000A5A8
Write 248 bytes at 0x0000A6A0
Write 248 bytes at 0x0000A798
Write 248 bytes at 0x0000A890
Write 248 bytes at 0x0000A988
Write 248 bytes at 0x0000AA80
Write 248 bytes at 0x0000AB78
Write 248 bytes at 0x0000AC70
Write 248 bytes at 0x0000AD68
Write 248 bytes at 0x0000AE60
Write 248 bytes at 0x0000AF58
Write 248 bytes at 0x0000B050
Write 248 bytes at 0x0000B148
Write 248 bytes at 0x0000B240
Write 248 bytes at 0x0000B338
Write 248 bytes at 0x0000B430
Write 248 bytes at 0x0000B528
Write 248 bytes at 0x0000B620
Write 248 bytes at 0x0000B718
Write 248 bytes at 0x0000B810
Write 248 bytes at 0x0000B908
Write 248 bytes at 0x0000BA00
Write 248 bytes at 0x0000BAF8
Write 248 bytes at 0x0000BBF0
Write 248 bytes at 0x0000BCE8
Write 248 bytes at 0x0000BDE0
Write 248 bytes at 0x0000BED8
Write 248 bytes at 0x0000BFD0
Write 248 bytes at 0x0000C0C8
Write 248 bytes at 0x0000C1C0
Write 248 bytes at 0x0000C2B8
Write 248 bytes at 0x0000C3B0
Write 248 bytes at 0x0000C4A8
Write 248 bytes at 0x0000C5A0
Write 248 bytes at 0x0000C698
Write 248 bytes at 0x0000C790
Write 248 bytes at 0x0000C888
Write 248 bytes at 0x0000C980
Write 248 bytes at 0x0000CA78
Write 248 bytes at 0x0000CB70
Write 248 bytes at 0x0000CC68
Write 248 bytes at 0x0000CD60
Write 248 bytes at 0x0000CE58
Write 248 bytes at 0x0000CF50
Write 248 bytes at 0x0000D048
Write 248 bytes at 0x0000D140
Write 248 bytes at 0x0000D238
Write 248 bytes at 0x0000D330
Write 248 bytes at 0x0000D428
Write 248 bytes at 0x0000D520
Write 248 bytes at 0x0000D618
Write 248 bytes at 0x0000D710
Write 248 bytes at 0x0000D808
Write 248 bytes at 0x0000D900
Write 248 bytes at 0x0000D9F8
Write 248 bytes at 0x0000DAF0
Write 248 bytes at 0x0000DBE8
Write 248 bytes at 0x0000DCE0
Write 248 bytes at 0x0000DDD8
Write 248 bytes at 0x0000DED0
Write 248 bytes at 0x0000DFC8
Write 248 bytes at 0x0000E0C0
Write 248 bytes at 0x0000E1B8
Write 248 bytes at 0x0000E2B0
Write 248 bytes at 0x0000E3A8
Write 248 bytes at 0x0000E4A0
Write 248 bytes at 0x0000E598
Write 248 bytes at 0x0000E690
Write 248 bytes at 0x0000E788
Write 248 bytes at 0x0000E880
Write 248 bytes at 0x0000E978
Write 248 bytes at 0x0000EA70
Write 248 bytes at 0x0000EB68
Write 248 bytes at 0x0000EC60
Write 248 bytes at 0x0000ED58
Write 248 bytes at 0x0000EE50
Write 248 bytes at 0x0000EF48
Write 248 bytes at 0x0000F040
Write 248 bytes at 0x0000F138
Write 248 bytes at 0x0000F230
Write 248 bytes at 0x0000F328
Write 248 bytes at 0x0000F420
Write 248 bytes at 0x0000F518
Write 248 bytes at 0x0000F610
Write 248 bytes at 0x0000F708
Write 248 bytes at 0x0000F800
Write 248 bytes at 0x0000F8F8
Write 248 bytes at 0x0000F9F0
Write 248 bytes at 0x0000FAE8
Write 248 bytes at 0x0000FBE0
Write 248 bytes at 0x0000FCD8
Write 248 bytes at 0x0000FDD0
Write 248 bytes at 0x0000FEC8
Write 248 bytes at 0x0000FFC0
Write 248 bytes at 0x000100B8
Write 248 bytes at 0x000101B0
Write 248 bytes at 0x000102A8
Write 248 bytes at 0x000103A0
Write 248 bytes at 0x00010498
Write 248 bytes at 0x00010590
Write 248 bytes at 0x00010688
Write 248 bytes at 0x00010780
Write 248 bytes at 0x00010878
Write 248 bytes at 0x00010970
Write 248 bytes at 0x00010A68
Write 248 bytes at 0x00010B60
Write 248 bytes at 0x00010C58
Write 248 bytes at 0x00010D50
Write 248 bytes at 0x00010E48
Write 248 bytes at 0x00010F40
Write 248 bytes at 0x00011038
Write 248 bytes at 0x00011130
Write 248 bytes at 0x00011228
Write 248 bytes at 0x00011320
Write 248 bytes at 0x00011418
Write 248 bytes at 0x00011510
Write 248 bytes at 0x00011608
Write 248 bytes at 0x00011700
Write 248 bytes at 0x000117F8
Write 248 bytes at 0x000118F0
Write 248 bytes at 0x000119E8
Write 248 bytes at 0x00011AE0
Write 248 bytes at 0x00011BD8
Write 248 bytes at 0x00011CD0
Write 248 bytes at 0x00011DC8
Write 248 bytes at 0x00011EC0
Write 248 bytes at 0x00011FB8
Write 248 bytes at 0x000120B0
Write 248 bytes at 0x000121A8
Write 248 bytes at 0x000122A0
Write 248 bytes at 0x00012398
Write 248 bytes at 0x00012490
Write 248 bytes at 0x00012588
Write 248 bytes at 0x00012680
Write 248 bytes at 0x00012778
Write 248 bytes at 0x00012870
Write 248 bytes at 0x00012968
Write 248 bytes at 0x00012A60
Write 248 bytes at 0x00012B58
Write 248 bytes at 0x00012C50
Write 248 bytes at 0x00012D48
Write 248 bytes at 0x00012E40
Write 248 bytes at 0x00012F38
Write 248 bytes at 0x00013030
Write 248 bytes at 0x00013128
Write 248 bytes at 0x00013220
Write 248 bytes at 0x00013318
Write 248 bytes at 0x00013410
Write 248 bytes at 0x00013508
Write 248 bytes at 0x00013600
Write 248 bytes at 0x000136F8
Write 248 bytes at 0x000137F0
Write 248 bytes at 0x000138E8
Write 248 bytes at 0x000139E0
Write 248 bytes at 0x00013AD8
Write 248 bytes at 0x00013BD0
Write 248 bytes at 0x00013CC8
Write 248 bytes at 0x00013DC0
Write 248 bytes at 0x00013EB8
Write 248 bytes at 0x00013FB0
Write 248 bytes at 0x000140A8
Write 248 bytes at 0x000141A0
Write 248 bytes at 0x00014298
Write 248 bytes at 0x00014390
Write 248 bytes at 0x00014488
Write 248 bytes at 0x00014580
Write 248 bytes at 0x00014678
Write 248 bytes at 0x00014770
Write 248 bytes at 0x00014868
Write 248 bytes at 0x00014960
Write 248 bytes at 0x00014A58
Write 248 bytes at 0x00014B50
Write 248 bytes at 0x00014C48
Write 248 bytes at 0x00014D40
Write 248 bytes at 0x00014E38
Write 248 bytes at 0x00014F30
Write 248 bytes at 0x00015028
Write 248 bytes at 0x00015120
Write 248 bytes at 0x00015218
Write 248 bytes at 0x00015310
Write 248 bytes at 0x00015408
Write 248 bytes at 0x00015500
Write 248 bytes at 0x000155F8
Write 248 bytes at 0x000156F0
Write 248 bytes at 0x000157E8
Write 248 bytes at 0x000158E0
Write 248 bytes at 0x000159D8
Write 248 bytes at 0x00015AD0
Write 248 bytes at 0x00015BC8
Write 248 bytes at 0x00015CC0
Write 248 bytes at 0x00015DB8
Write 248 bytes at 0x00015EB0
Write 248 bytes at 0x00015FA8
Write 248 bytes at 0x000160A0
Write 248 bytes at 0x00016198
Write 248 bytes at 0x00016290
Write 248 bytes at 0x00016388
Write 248 bytes at 0x00016480
Write 248 bytes at 0x00016578
Write 248 bytes at 0x00016670
Write 248 bytes at 0x00016768
Write 248 bytes at 0x00016860
Write 248 bytes at 0x00016958
Write 248 bytes at 0x00016A50
Write 248 bytes at 0x00016B48
Write 248 bytes at 0x00016C40
Write 248 bytes at 0x00016D38
Write 248 bytes at 0x00016E30
Write 248 bytes at 0x00016F28
Write 248 bytes at 0x00017020
Write 248 bytes at 0x00017118
Write 248 bytes at 0x00017210
Write 248 bytes at 0x00017308
Write 248 bytes at 0x00017400
Write 248 bytes at 0x000174F8
Write 248 bytes at 0x000175F0
Write 248 bytes at 0x000176E8
Write 248 bytes at 0x000177E0
Write 248 bytes at 0x000178D8
Write 248 bytes at 0x000179D0
Write 248 bytes at 0x00017AC8
Write 248 bytes at 0x00017BC0
Write 248 bytes at 0x00017CB8
Write 248 bytes at 0x00017DB0
Write 248 bytes at 0x00017EA8
Write 248 bytes at 0x00017FA0
Write 248 bytes at 0x00018098
Write 248 bytes at 0x00018190
Write 248 bytes at 0x00018288
Write 248 bytes at 0x00018380
Write 248 bytes at 0x00018478
Write 248 bytes at 0x00018570
Write 248 bytes at 0x00018668
Write 248 bytes at 0x00018760
Write 248 bytes at 0x00018858
Write 248 bytes at 0x00018950
Write 248 bytes at 0x00018A48
Write 248 bytes at 0x00018B40
Write 248 bytes at 0x00018C38
Write 248 bytes at 0x00018D30
Write 248 bytes at 0x00018E28
Write 248 bytes at 0x00018F20
Write 248 bytes at 0x00019018
Write 248 bytes at 0x00019110
Write 248 bytes at 0x00019208
Write 248 bytes at 0x00019300
Write 248 bytes at 0x000193F8
Write 248 bytes at 0x000194F0
Write 248 bytes at 0x000195E8
Write 248 bytes at 0x000196E0
Write 248 bytes at 0x000197D8
Write 248 bytes at 0x000198D0
Write 248 bytes at 0x000199C8
Write 248 bytes at 0x00019AC0
Write 248 bytes at 0x00019BB8
Write 248 bytes at 0x00019CB0
Write 248 bytes at 0x00019DA8
Write 248 bytes at 0x00019EA0
Write 248 bytes at 0x00019F98
Write 248 bytes at 0x0001A090
Write 248 bytes at 0x0001A188
Write 248 bytes at 0x0001A280
Write 248 bytes at 0x0001A378
Write 248 bytes at 0x0001A470
Write 248 bytes at 0x0001A568
Write 248 bytes at 0x0001A660
Write 248 bytes at 0x0001A758
Write 248 bytes at 0x0001A850
Write 248 bytes at 0x0001A948
Write 248 bytes at 0x0001AA40
Write 248 bytes at 0x0001AB38
Write 248 bytes at 0x0001AC30
Write 248 bytes at 0x0001AD28
Write 248 bytes at 0x0001AE20
Write 248 bytes at 0x0001AF18
Write 248 bytes at 0x0001B010
Write 248 bytes at 0x0001B108
Write 248 bytes at 0x0001B200
Write 248 bytes at 0x0001B2F8
Write 248 bytes at 0x0001B3F0
Write 248 bytes at 0x0001B4E8
Write 248 bytes at 0x0001B5E0
Write 248 bytes at 0x0001B6D8
Write 248 bytes at 0x0001B7D0
Write 248 bytes at 0x0001B8C8
Write 248 bytes at 0x0001B9C0
Write 248 bytes at 0x0001BAB8
Write 248 bytes at 0x0001BBB0
Write 248 bytes at 0x0001BCA8
Write 248 bytes at 0x0001BDA0
Write 248 bytes at 0x0001BE98
Write 248 bytes at 0x0001BF90
Write 248 bytes at 0x0001C088
Write 248 bytes at 0x0001C180
Write 248 bytes at 0x0001C278
Write 248 bytes at 0x0001C370
Write 248 bytes at 0x0001C468
Write 248 bytes at 0x0001C560
Write 248 bytes at 0x0001C658
Write 248 bytes at 0x0001C750
Write 248 bytes at 0x0001C848
Write 248 bytes at 0x0001C940
Write 248 bytes at 0x0001CA38
Write 248 bytes at 0x0001CB30
Write 248 bytes at 0x0001CC28
Write 248 bytes at 0x0001CD20
Write 248 bytes at 0x0001CE18
Write 248 bytes at 0x0001CF10
Write 248 bytes at 0x0001D008
Write 248 bytes at 0x0001D100
Write 248 bytes at 0x0001D1F8
Write 248 bytes at 0x0001D2F0
Write 248 bytes at 0x0001D3E8
Write 248 bytes at 0x0001D4E0
Write 248 bytes at 0x0001D5D8
Write 248 bytes at 0x0001D6D0
Write 248 bytes at 0x0001D7C8
Write 248 bytes at 0x0001D8C0
Write 248 bytes at 0x0001D9B8
Write 248 bytes at 0x0001DAB0
Write 248 bytes at 0x0001DBA8
Write 248 bytes at 0x0001DCA0
Write 248 bytes at 0x0001DD98
Write 248 bytes at 0x0001DE90
Write 248 bytes at 0x0001DF88
Write 248 bytes at 0x0001E080
Write 248 bytes at 0x0001E178
Write 248 bytes at 0x0001E270
Write 248 bytes at 0x0001E368
Write 248 bytes at 0x0001E460
Write 248 bytes at 0x0001E558
Write 248 bytes at 0x0001E650
Write 248 bytes at 0x0001E748
Write 248 bytes at 0x0001E840
Write 248 bytes at 0x0001E938
Write 248 bytes at 0x0001EA30
Write 248 bytes at 0x0001EB28
Write 248 bytes at 0x0001EC20
Write 248 bytes at 0x0001ED18
Write 248 bytes at 0x0001EE10
Write 248 bytes at 0x0001EF08
Write 248 bytes at 0x0001F000
Write 248 bytes at 0x0001F0F8
Write 248 bytes at 0x0001F1F0
Write 248 bytes at 0x0001F2E8
Write 248 bytes at 0x0001F3E0
Write 248 bytes at 0x0001F4D8
Write 248 bytes at 0x0001F5D0
Write 248 bytes at 0x0001F6C8
Write 248 bytes at 0x0001F7C0
Write 248 bytes at 0x0001F8B8
Write 248 bytes at 0x0001F9B0
Write 248 bytes at 0x0001FAA8
Write 248 bytes at 0x0001FBA0
Write 248 bytes at 0x0001FC98
Write 248 bytes at 0x0001FD90
Write 248 bytes at 0x0001FE88
Write 248 bytes at 0x0001FF80
Write 248 bytes at 0x00020078
Write 248 bytes at 0x00020170
Write 248 bytes at 0x00020268
Write 248 bytes at 0x00020360
Write 248 bytes at 0x00020458
Write 248 bytes at 0x00020550
Write 248 bytes at 0x00020648
Write 248 bytes at 0x00020740
Write 248 bytes at 0x00020838
Write 248 bytes at 0x00020930
Write 248 bytes at 0x00020A28
Write 248 bytes at 0x00020B20
Write 248 bytes at 0x00020C18
Write 248 bytes at 0x00020D10
Write 248 bytes at 0x00020E08
Write 248 bytes at 0x00020F00
Write 248 bytes at 0x00020FF8
Write 248 bytes at 0x000210F0
Write 248 bytes at 0x000211E8
Write 248 bytes at 0x000212E0
Write 248 bytes at 0x000213D8
Write 248 bytes at 0x000214D0
Write 248 bytes at 0x000215C8
Write 248 bytes at 0x000216C0
Write 248 bytes at 0x000217B8
Write 248 bytes at 0x000218B0
Write 248 bytes at 0x000219A8
Write 248 bytes at 0x00021AA0
Write 248 bytes at 0x00021B98
Write 248 bytes at 0x00021C90
Write 248 bytes at 0x00021D88
Write 248 bytes at 0x00021E80
Write 248 bytes at 0x00021F78
Write 248 bytes at 0x00022070
Write 248 bytes at 0x00022168
Write 248 bytes at 0x00022260
Write 248 bytes at 0x00022358
Write 248 bytes at 0x00022450
Write 248 bytes at 0x00022548
Write 248 bytes at 0x00022640
Write 248 bytes at 0x00022738
Write 248 bytes at 0x00022830
Write 248 bytes at 0x00022928
Write 248 bytes at 0x00022A20
Write 248 bytes at 0x00022B18
Write 248 bytes at 0x00022C10
Write 248 bytes at 0x00022D08
Write 248 bytes at 0x00022E00
Write 248 bytes at 0x00022EF8
Write 248 bytes at 0x00022FF0
Write 248 bytes at 0x000230E8
Write 248 bytes at 0x000231E0
Write 248 bytes at 0x000232D8
Write 248 bytes at 0x000233D0
Write 248 bytes at 0x000234C8
Write 248 bytes at 0x000235C0
Write 248 bytes at 0x000236B8
Write 248 bytes at 0x000237B0
Write 248 bytes at 0x000238A8
Write 248 bytes at 0x000239A0
Write 248 bytes at 0x00023A98
Write 248 bytes at 0x00023B90
Write 248 bytes at 0x00023C88
Write 248 bytes at 0x00023D80
Write 248 bytes at 0x00023E78
Write 248 bytes at 0x00023F70
Write 248 bytes at 0x00024068
Write 248 bytes at 0x00024160
Write 248 bytes at 0x00024258
Write 248 bytes at 0x00024350
Write 248 bytes at 0x00024448
Write 248 bytes at 0x00024540
Write 248 bytes at 0x00024638
Write 248 bytes at 0x00024730
Write 248 bytes at 0x00024828
Write 248 bytes at 0x00024920
Write 248 bytes at 0x00024A18
Write 248 bytes at 0x00024B10
Write 248 bytes at 0x00024C08
Write 248 bytes at 0x00024D00
Write 248 bytes at 0x00024DF8
Write 248 bytes at 0x00024EF0
Write 248 bytes at 0x00024FE8
Write 248 bytes at 0x000250E0
Write 248 bytes at 0x000251D8
Write 248 bytes at 0x000252D0
Write 248 bytes at 0x000253C8
Write 248 bytes at 0x000254C0
Write 248 bytes at 0x000255B8
Write 248 bytes at 0x000256B0
Write 248 bytes at 0x000257A8
Write 248 bytes at 0x000258A0
Write 248 bytes at 0x00025998
Write 248 bytes at 0x00025A90
Write 248 bytes at 0x00025B88
Write 248 bytes at 0x00025C80
Write 248 bytes at 0x00025D78
Write 248 bytes at 0x00025E70
Write 248 bytes at 0x00025F68
Write 248 bytes at 0x00026060
Write 248 bytes at 0x00026158
Write 248 bytes at 0x00026250
Write 248 bytes at 0x00026348
Write 248 bytes at 0x00026440
Write 248 bytes at 0x00026538
Write 248 bytes at 0x00026630
Write 248 bytes at 0x00026728
Write 248 bytes at 0x00026820
Write 248 bytes at 0x00026918
Write 248 bytes at 0x00026A10
Write 248 bytes at 0x00026B08
Write 248 bytes at 0x00026C00
Write 248 bytes at 0x00026CF8
Write 248 bytes at 0x00026DF0
Write 248 bytes at 0x00026EE8
Write 248 bytes at 0x00026FE0
Write 248 bytes at 0x000270D8
Write 248 bytes at 0x000271D0
Write 248 bytes at 0x000272C8
Write 248 bytes at 0x000273C0
Write 248 bytes at 0x000274B8
Write 248 bytes at 0x000275B0
Write 248 bytes at 0x000276A8
Write 248 bytes at 0x000277A0
Write 248 bytes at 0x00027898
Write 248 bytes at 0x00027990
Write 248 bytes at 0x00027A88
Write 248 bytes at 0x00027B80
Write 248 bytes at 0x00027C78
Write 248 bytes at 0x00027D70
Write 248 bytes at 0x00027E68
Write 248 bytes at 0x00027F60
Write 248 bytes at 0x00028058
Write 248 bytes at 0x00028150
Write 248 bytes at 0x00028248
Write 248 bytes at 0x00028340
Write 248 bytes at 0x00028438
Write 248 bytes at 0x00028530
Write 248 bytes at 0x00028628
Write 248 bytes at 0x00028720
Write 248 bytes at 0x00028818
Write 248 bytes at 0x00028910
Write 248 bytes at 0x00028A08
Write 248 bytes at 0x00028B00
Write 248 bytes at 0x00028BF8
Write 248 bytes at 0x00028CF0
Write 248 bytes at 0x00028DE8
Write 248 bytes at 0x00028EE0
Write 248 bytes at 0x00028FD8
Write 248 bytes at 0x000290D0
Write 248 bytes at 0x000291C8
Write 248 bytes at 0x000292C0
Write 248 bytes at 0x000293B8
Write 248 bytes at 0x000294B0
Write 248 bytes at 0x000295A8
Write 248 bytes at 0x000296A0
Write 248 bytes at 0x00029798
Write 248 bytes at 0x00029890
Write 248 bytes at 0x00029988
Write 248 bytes at 0x00029A80
Write 248 bytes at 0x00029B78
Write 248 bytes at 0x00029C70
Write 248 bytes at 0x00029D68
Write 248 bytes at 0x00029E60
Write 248 bytes at 0x00029F58
Write 248 bytes at 0x0002A050
Write 248 bytes at 0x0002A148
Write 248 bytes at 0x0002A240
Write 248 bytes at 0x0002A338
Write 248 bytes at 0x0002A430
Write 248 bytes at 0x0002A528
Write 248 bytes at 0x0002A620
Write 248 bytes at 0x0002A718
Write 248 bytes at 0x0002A810
Write 248 bytes at 0x0002A908
Write 248 bytes at 0x0002AA00
Write 248 bytes at 0x0002AAF8
Write 248 bytes at 0x0002ABF0
Write 248 bytes at 0x0002ACE8
Write 248 bytes at 0x0002ADE0
Write 248 bytes at 0x0002AED8
Write 248 bytes at 0x0002AFD0
Write 248 bytes at 0x0002B0C8
Write 248 bytes at 0x0002B1C0
Write 248 bytes at 0x0002B2B8
Write 248 bytes at 0x0002B3B0
Write 248 bytes at 0x0002B4A8
Write 248 bytes at 0x0002B5A0
Write 248 bytes at 0x0002B698
Write 248 bytes at 0x0002B790
Write 248 bytes at 0x0002B888
Write 248 bytes at 0x0002B980
Write 248 bytes at 0x0002BA78
Write 248 bytes at 0x0002BB70
Write 248 bytes at 0x0002BC68
Write 248 bytes at 0x0002BD60
Write 248 bytes at 0x0002BE58
Write 248 bytes at 0x0002BF50
Write 248 bytes at 0x0002C048
Write 104 bytes at 0x00057F98
Write done
Verifying by comparing CRC32 calculations.
Verified (match: 0xe83aa727)
[17:50:06] INFO: cc2652-flasher-up script exited with code 0
s6-rc: info: service cc2652-flasher successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service cc2652-flasher: stopping
s6-rc: info: service cc2652-flasher successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Exactly the same problem here, using SkyConnect on a 2m USB lead. Nothing in the logs - ZHA seems to be unaware that there is a problem. All my devices are Philips Hue and worked flawlessly with the Hue bridge.
The devices failing are always motion sensors - my solution is to wake them up with a short press on the reset button, then they re-pair with the co-ordinator.
Tell me about it. The only way to tell they’re not working is to walk around phone in hand watching for the sensors that don’t react.
There’s something similar reported on Github where the feeling seems to be that problems started with the May update.
Your procedure worked and now i’m on Coordinator revision 20230507. Thanks!
After the procedure Zigbee2MQTT announced that it was “configuring” 3 devices. No idea how it picked the 3 out of the list and what changed once it “configured” them. Will be watching for failures now. Hopefully this fixes an issue. If not, the USB extension is next thing I’ll try.
I lost a few devices since updating the Coordinator revision. Then I got an extension cord for the dongle. I brought back all zigbee devices to live and left for a 12 day vacation.
I lost a Zigbee device almost every day. Towards the end of vacation my house had no viable security system left. I said to myself - enough of this, I gave HA way more than a reasonable try, it’s time to go back to SmartThings and use Zigbee via HA’s SmartThings integration.
And then the Z-Wave JS UI upgrade comes out. I installed it and I lost entire Z-Wave network. Not a single Z-Wave device available. At that point only Bluetooth devices continued to work.
I got home and rebooted the PC running HAOS. To my disbelief, 100% of Zigbee and 100% of Z-Wave devices came back.
I don’t know what to think anymore. Maybe instead of going around the house each evening reinserting the batteries I should be rebooting HAOS PC? Should I somehow do this via an automation triggered by a device becoming unavailable? This is becoming tragicomical.
That’s odd for sure. I haven’t restarted HA in like two weeks and everything is churning along nicely. I’m sure there are others that have gone longer.
It seems to me that your problem is the low signal from the dongle P. I was having a lot of problems in a certain room in the house, I placed a router close to that room and changed the position of the coordinator. my problems are over. But even so, I’m thinking about exchanging the P dongle for the E.
But isn’t Sonoff P-dongle the most supported/recommended option?
A few of you suggested signal issues. I must have some fundamental flaws in my understanding how zigbee works. Wouldn’t signal issues be:
More prominent for devices further away, with lower LQI?
Not fixable by removing/reinserting battery?
Not fixable by rebooting the HAOS PC?
Sometimes reconnect on their own?
Be intermittent?
All devices are affected equally in my case, from those a few ft away to most distant. Reinserting the battery almost always fixes instantly. Rebooting HAOS PC fixes it, but only if I unplug the power/plug back in. Proxmox node reboot doesn’t help. And once a device goes unavailable, it never comes back on it’s own.
One device became unavailable since my post yesterday. Restarting HAOS did nothing. I rebooted the node via Proxmox and now the entity itself is gone! The device just vanished from the Zigbee2MQTT dashboard as well. How is that even possible? I’ll unplug/plug back in the PC when I’m home in the evening but it’s getting weirder and weirder.
Something has changed. My nightly zigbee wack-a-mole used to be checking which devices turned “unavailable” and reinserting the batteries. I lost 2 more devices since previous post and both are completely gone from zigbee2mqtt, and the dashboards show them as “entity unavailable”.
Till now I never had a zigbee entity disappear. They used to become unavailable and stayed that way unless I manually deleted them. Has anyone observed this change? Could it be due to the recent core updates? How can I get back to the previous behavior?
And as I was looking at zigbe2mqtt UI suddenly it announced “Sauna sensor has left the network”! How? Why? Devices stayed unavailable for over a week when I was on vacation and never left the network. How do I stop this?
