WADWAZ-1 Door/Window Sensor w/ Open Z-Wave
Has anyone used this sensor? WADWAZ-1 it was sold under GoControl but I hear others are identical.
I’m moving over from my old Vera to Open Zwave, and while there have been bumps, things got better with 0.114.
With the Vera it would properly register “Open” continually when it wasn’t in contact with the magnet. With Open Z-Wave it is behaving more like a momentary switch, going back to “Closed” after 5 seconds even if the door/window is left open.
Answering this myself. I found that there were several entities for this device disabled by default in HA/OZW. Enabling one of them located the proper binary sensor that correctly identifies an open/close state. It seems the config for OZW might need some tweaking to swap these sensors as I personally think the vendor intended it to operate as expected.
