If somebody is interesting in modbus/tcp control of Wafe 350 reccuperation unit, here you are basic scripts for controlling unit over tcp.
Thanks for sharing, I have WAFE 201Ehopefully it will be similar.
Just in case someone else would be adding Wafe 201E to HomeAssistatn here is the Modbus documentation for this unit. The company seems to be going trough rough times and it is not sure if they will exist.
Hello, did you manage to add Wafe 201E to Home Assistant?
Yes, will send you the config in the evening.
Great, it would help me Thank you very much.
Hi Jakub,
let me post it here for others as well.
# Rekuperace
- name: "Rekuperace"
type: tcp
host: 192.168.1.246
port: 502
delay: 2
timeout: 5
switches:
- name: "Rekuperace - krátký boost"
address: 7
slave: 1
write_type: coil
- name: "Rekuperace - dlouhý boost"
address: 8
slave: 1
write_type: coil
sensors:
- name: "Rekuperace - venkovní vzduch"
device_class: temperature
unit_of_measurement: °C
slave: 1
address: 1005
input_type: input
scale: 0.1
precision: 1
scan_interval: 301 # 5 min
- name: "Rekuperace - čerstvý vzduch"
slave: 1
address: 1006
input_type: input
scale: 0.1
precision: 1
scan_interval: 303 # cca 5 min - posunutí kvůli tomu, aby nedocházelo ke čtění dat z rekuperace ve stejný čas
- name: "Rekuperace - odtahovaný vzduch"
slave: 1
address: 1007
input_type: input
scale: 0.1
precision: 1
scan_interval: 306 # cca 5 min - posunutí kvůli tomu, aby nedocházelo ke čtění dat z rekuperace ve stejný čas
- name: "Rekuperace - odpadní vzduch"
slave: 1
address: 1008
input_type: input
scale: 0.1
precision: 1
scan_interval: 309 # 5 min - posunutí kvůli tomu, aby nedocházelo ke čtění dat z rekuperace ve stejný čas
- name: "Rekuperace - oxid uhličitý"
device_class: carbon_dioxide
unit_of_measurement: ppm
slave: 1
address: 1009
input_type: input
scan_interval: 61 # 1 min - posunutí kvůli tomu, aby nedocházelo ke čtění dat z rekuperace ve stejný čas
Thank you, I’ll test it.
Hi, where did you get the IP of the unit please?
