Hi!
I have run into a problem that has been flagged by various people multiple times already, however reading through their threads I have not found the solution for my case.
Situation:
I have a Shelly Dimmer2 built into the light switch behind the physical switch in my toilet. This works flawlessly. I also have an Aqara Motion Sensor in there, which I want to use to control the lights, without people needing to use the switch. I previously used the blueprint ‘Blackshome/sensor-light.yaml’ but I found I wanted more control over the light levels, having effectively 3 levels of brightness, instead of 2. So, I started writing my own blueprint, keeping an eye on the other blueprint for inspiration. My blueprint/automation works partly, however it always seems to get stuck at the ‘wait_for_trigger’ step. So: initial triggering to turn on the light works, ‘calculation’ of the light level works, turning the light on works, and then the wait_for_trigger gets activated. The problem is that this wait_for_trigger never clears, despite the actual sensor going to ‘clear’.
Things DID work well with Blackshome’s blueprint before, and I have managed to use the wait_for_trigger successfully in scripts and automations elsewhere. I just can’t seem to get it to behave in this blueprint
The code:
Blueprint:
blueprint:
name: Toilet Light Control Blueprint
description: Turn a light on based on a sensor with variable light levels
domain: automation
input:
motion_sensor:
description: This sensor will control the light
selector:
entity:
domain: binary_sensor
device_class: motion
target_light:
description: This is the light that is being controlled
selector:
entity:
domain: light
brightness_day:
name: Brightness for daytime use
description: This is the brightness that will be used if the light is triggered during the daytime.
selector:
number:
min: 0
max: 255
brightness_evening:
name: Brightness for evening use
description: This is the brightness that will be used if the light is triggered during the evening.
selector:
number:
min: 0
max: 255
mode: slider
brightness_night:
name: Brightness for night use
description: This is the brightness that will be used if the light is triggered during the night.
selector:
number:
min: 0
max: 255
mode: slider
transition_time:
description: This is the time it takes to go from off to on, or on to off if the light supports that.
selector:
number:
min: 0
max: 10
unit_of_measurement: 'seconds'
mode: box
minutes_after_cleared:
name: Minutes after cleared
description: This is the time the automation waits after the motion sensor cleared to turn the lights off again.
selector:
number:
min: 0
max: 10
unit_of_measurement: 'minutes'
mode: box
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input motion_sensor
- alias: Setting variables and calculating desired brightness
variables:
var_motion_sensor: !input motion_sensor
var_brightness_day: !input brightness_day
var_brightness_evening: !input brightness_evening
var_brightness_night: !input brightness_night
var_brightness: >-
{% if states('input_boolean.alexanight') == 'off' and states('sun.sun') == 'above_horizon' %} {{ var_brightness_day | int }} {% elif
states('input_boolean.alexanight') == 'off' and states('sun.sun') == 'below_horizon' %} {{ var_brightness_evening | int }} {% elif
states('input_boolean.alexanight') == 'on' and states('sun.sun') == 'above_horizon' %} {{ var_brightness_evening | int }} {% elif
states('input_boolean.alexanight') == 'on' and states('sun.sun') == 'below_horizon' %} {{ var_brightness_night | int }} {% endif %}
- service: persistent_notification.create
message: >
Testing!
motion sensor: {{ var_motion_sensor }}
brightness: {{ var_brightness }}
title: 'Template test'
enabled: false
- alias: Turn target_light on
service: light.turn_on
entity_id: !input target_light
brightness: "{{ var_brightness }}"
transition: !input transition_time
- alias: Wait for motion sensor to clear
wait_for_trigger:
platform: state
to: 'off'
- alias: Wait minutes_after_cleared number of minutes to continue
delay:
minutes: !input minutes_after_cleared
- alias: Turn target_light off
service: light.turn_off
Note that the ‘input_boolean.alexanight’ is a boolean that is controlled elsewhere. Since it’s just read here and would be shared by all, I didn’t want to use an blueprint input for that (yet).
Section from automations.yaml:
- id: '1681241056220'
alias: Toilet Light Downstairs
description: Toilet Light Downstairs automation
use_blueprint:
path: shoikan/toilet_light_control.yaml
input:
motion_sensor: binary_sensor.lumi_toilet_downstairs_iaszone
target_light: light.shellydimmertoilet1
brightness_day: 255
brightness_evening: 50
brightness_night: 10
transition_time: 2
minutes_after_cleared: 2
Trace of such an event:
Conclusion
I am fairly certain the trigger entity is correct, since the light does get turned on. I feel the issue is there somewhere though, I just can’t seem to find what the wait_for_trigger is actually waiting for (maybe/probably I did something wrong there but I can’t find the smoking gun for this). Also note I do not want to use the timeout, I just want the trigger on the sensor clearing to work
Any help in either troubleshooting this, or solving this would be very much appreciated.
