Hi all,
I recently moved from Fibaro to Home Assistent and so far loving the possibilities. I have most automations and scripts setup but one still is not working as I would expect it to do.
I have a script that finalizes the morning automation. In winter time the script should wait until the light passes a specific value stored in a variable. In summer the light level is alsways past that value and should continue right away. I use the following code to achieve that but the “waiy for trigger” time-out even when the light level is way above the set level. What is whrong or what am I missing:
alias: Routine - Sluit ochtend af
sequence:
- wait_for_trigger:
value_template: >-
{{ states('sensor.buitensensor_achter_illuminance') | float >
states('input_number.lichtdrempel') | float }}
timeout: '3600'
- service: scene.turn_on
data: {}
entity_id: scene.alle_lichten_uit
Thanks.
