I am working on an automation to switch on/off a fan in our basement, to reduce humidity. My first approach does work, but not as smoothley, as I hoped. (-> Reduce humidity in basement - automation does not work)
I want to try a different approach, but I am struggling with the “wait_template” in my automation.
My idea:
- My automation does start the fan as expected.
- To switch the fan off, I added two conditions in the wait_template. If one or the other is true, the fan should stop. Unfortunately, there seems to be something wrong and the fan never stops.
Any help is very much appreciated.
alias: Garage Lüfter Steuerung v2
description: Schaltet Lüfter, um Raum zu entfeuchten
- platform: state
entity_id: binary_sensor.openweathermap_dewpoint_trend_rising
to: 'off'
for: '00:15:00'
- platform: state
entity_id: binary_sensor.tasmota_am2301_dewpoint_2_vs_garten
to: 'off'
condition:
- condition: state
state: 'off'
- condition: state
state: 'off'
- service: switch.turn_on
entity_id: switch.tasmota_2
- wait_template: >
"{{ is_state("binary_sensor.openweathermap_dewpoint_trend_rising", "on")
or is_state("binary_sensor.tasmota_am2301_dewpoint_2_vs_garten", "on") }}"
- service: switch.turn_off
mode: single
- wait_for_trigger:
- platform: state
entity_id: 'binary_sensor.openweathermap_dewpoint_trend_rising'
to: 'on'
- platform: state
to: 'on'
mode: single
thank you very much for your quick help. Do I understand this correctly, that the two conditions in the wait_for_trigger are AND-conditions? How do I make it OR?
I think it will work
- platform: state
to: 'off'
for: '00:15:00'
- platform: state
to: 'off'
- wait_for_trigger:
- platform: state
to: 'on'
- platform: state
to: 'on'
mode: single
Try removing the quotes-
- platform: state
to: 'off'
for: '00:15:00'
- platform: state
to: 'off'
condition:
- condition: state
state: 'off'
- condition: state
state: 'off'
- wait_template: >
mode: single
Note that wait_template does not survive Home Assistant reboot/crashes.
It’s better if you do specify all the triggers (OFF and ON) and use choose action-
- platform: state
to: 'off'
for: '00:15:00'
- platform: state
- platform: state
to: 'on'
condition: []
- choose:
- conditions:
- condition: template
value_template: >-
{{ trigger.to_state.state == 'off' }}
- condition: state
state: 'off'
- condition: state
state: 'off'
sequence:
default:
Thank you both for your inputs, very much appreciated!
ardysusilo
I ended up editing my automation in the file-editor-app in HA. there, the syntax highliting seems to be okay, when using this. I will test it and report back, if it works.
- wait_template: "{{ is_state('binary_sensor.openweathermap_dewpoint_trend_rising', 'on') or is_state('binary_sensor.tasmota_am2301_dewpoint_vs_garten', 'on') }}"
I do not yet fully understand your second proposal, but I tried to create an automation according to my understanding.
- id: '1629661133929'
alias: Garage Lüfter Steuerung v4
description: Lüfter in Garage steuern
trigger: # all relevant triggers are mentioned here
- platform: state
entity_id: binary_sensor.openweathermap_dewpoint_trend_rising # if dew point outside is rising above a defined rate, fan should be switched off - else switched on
to: 'off'
for: 00:15:00
- platform: state
entity_id: binary_sensor.tasmota_am2301_dewpoint_2_vs_garten # of dew point outside rises above dew point inside, fan should be switched off - else switched on
to: 'off'
- platform: state
entity_id: binary_sensor.openweathermap_dewpoint_trend_rising # see first trigger
to: 'on'
- platform: state
entity_id: binary_sensor.tasmota_am2301_dewpoint_2_vs_garten # see second trigger
to: 'on'
condition: []
- choose:
- conditions:
- condition: state
state: 'off'
value_template: "{{ states('sensor.tasmota_am2301_dewpoint_2')|float > states('sensor.openweathermap_dew_point')|float }}"
sequence:
- conditions:
- condition: state
state: 'off'
- condition: state
state: 'off'
sequence:
default:
mode: single
I will test this for at least 24h and report back.
Unfortunately, this does not work. It never triggers the action to stop.
But the other automation with the “choose”-function seems to do the job.
